bagpiper46's Avatar
No emergancy flashers or turn signals?
They just went dead. Everything else works just cant get them to work. Checked all the fuses, relays and even jiggled the emergancy flasher unit. Wife said it happened when she drove it 2 weeks ago while I was hunting in her Jeep. She now hates my car. Afraid it will break and cost thousands to fix. I did have to re-glue the rear view mirror ($2.95). Any ideas on the turn signal/emergancy flasher issue? 911 81 SC.
Old 11-11-2005, 08:54 PM
bagpiper46's Avatar
So it might be a $32 relay? Where would it be located??
Old 11-11-2005, 09:03 PM
Check you turn signal switch, and the headlight switch.
mine get lose or something, after messing with those switchs, I found that my light came back on.
Derek Oxford PCA - Nationally Certified Instructor
2002 Boxster S ( race car)
2010 LR4 2009 GMC Sierra (Porsche Support
2011 M3 4Door
Old 11-11-2005, 09:14 PM
Send a message via AIM to fintstone
Since both the emergency flasher and turn signals are out, it is most likely the flasher (there is no relay except inside the flasher).
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 11-11-2005, 09:52 PM
Do your brake lights worK? Also, do you have a voltmeter of test light to check the power to the flasher?
Old 11-11-2005, 09:54 PM
bagpiper46's Avatar
Fixed it! Thanks again to the BB. It was the relay loose inside the trunk up behind the carpet to the right of the brake fluid resevoir. Jiggled it and they work again! I really rely on you guys and this BB becuase nobody in this town of 13,000 does work on Porsche's except me (and I aint touchin the other guys porche's. I think he has a 1995 and a 1960's 356) .
Found it on a search and looked for it and there it was.
Now I just need courage for the upcoming valve adjust this spring.
Old 11-12-2005, 07:43 AM
