2.7 Badge
Is there such a thing as a 2.7 grill badge ?? If so, which year(s) had them ? Perhaps, if they existed, they're removed on purpose ?? Sort of a form of camafloge ?
If it doesn't leak, you're out of oil.
If you took a picture of a Porsche and put it in your shirt pocket it would leak oil on your shirt.
Screw Flanders....
I'm goin' to Moe's.
Old 06-26-2004, 12:58 PM
Pat S's Avatar
I've got one on my 74.
Current: 07 S4 Avant, 06 Volvo S60R
Sold: '74 911, 01 986, 93 Volvo 240
Old 06-26-2004, 01:42 PM
'72 and '73 911s had a 2.4 badge, while '74-'77 911s had a 2.7 badge. Our host sells the 2.7 badges here:
http://www.pelicanparts.com/catalog/shopcart/911E/POR_911E_exteri_pg1.htm#item2
-Jim
Old 06-26-2004, 03:20 PM
They came on a few '73 cars too.
Brian
'73 Carrera RS
'71 911S coupe 'Patrick'
'16 Cayman GT4
'91 C4 coupe
Old 06-26-2004, 07:44 PM
safe's Avatar
jim72911t: Are you sure about that? I have seen two 77s, including mine, that doesn't have the 2.7 badge. I think I have read somewhere that itīs only the 74-75 (and the 73rs) that has it.
Magnus
Old 06-27-2004, 10:28 AM
I stand corrected!!
-Jim
Old 06-27-2004, 10:23 PM
klaucke's Avatar
Gratuitis Pic
Looks like this:
Old 06-28-2004, 05:05 AM
PP sells it. But they say it's attached with 2sided sticky tape. Not included.
How does that work out on the grill strips. Doesn't seem very secure. It that really how the (stock) badge is attached ? Or any other engine badge for that matter ?
You'd think there would be some through fasteners or something.
If so, is there some sort or "industrial strength" sticky tape that is used?
Screw Flanders....
I'm goin' to Moe's.
Old 06-28-2004, 07:19 AM
Pat S's Avatar
Stock one attached with double sided tape to an equal sized bracket made of a very soft metal that fit inside the emblem. There are 4 small holes in the grill and this bracket has little nubs that are pressed into the grill.
I took mine off when I refinished my grill and when I reapplied it I used 3M doublesided tape and did not press the feet back in the holes. It has held up fine over the past 3 months or so since I did it. 3M tape is some pretty strong stuff and holds very well.
Pat
Old 06-28-2004, 08:00 AM
Pat,
If I understand you correctly, just sticking it to the grill strips isn't going to hold it very secure.
The chance of finding the little bracket is probably slim at best. Not sure I want to spen $30 and have the thing melt off in 2 mins. when the temp gets a little warm.
I'll look for the small holes just to satisfy my curiousity.
Screw Flanders....
I'm goin' to Moe's.
Old 06-28-2004, 08:43 AM
Pat S's Avatar
No, I think just sticking it on with 3M trim tape WILL hold well. Just make sure the surface is clean. You get a pretty good surface area and they don't weigh anything.
I'd post a WTB and see if you can find a used one cheap. Then try it out.
Pat
Old 06-28-2004, 10:59 AM
Hey, thanx Pat.
Screw Flanders....
I'm goin' to Moe's.
Old 06-28-2004, 11:29 AM
