Porsche air compressor
After reading the few threads about flat tires. I went out and tested my original 1987 air compressor that came with the car. I could not get it to work. Yes the cigarette lighter works and I did have the key turned on. Does anybody have any suggestions. thanks, Jerry Baer
Jerry Baer 87 Carrera Coupe |
I have a similar problem with a '92 compressor. when I plug it in it blows the fuse on the cig. lighter circuit. obviously there is a short somewhere but I started to pry the two halves apart and I felt like I was going to break it. Any hints?
TIA
Andy |
Buy a pair of alligator clips, replace the cigarrette lighter connector and connect the compressor directly from the battery. I have the same compressor and it blows the fuse of the cigarette lighter. With the alligator clips no more problems.
1972 911T 1991 Mazda RX-7 Turbo II Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life! |
Thanks,
Andy |
OK the alligator clips will work for KobaltBlau, but what about my situation. My compressor does not work at all. Is there a fuse or relay or something that can be changed in the compressor? thanks,
yogi, I'm not sure if my '92 compressor is like your '87. I think so, Intermatic in a black box? I don't know of any fuses or relays to replace, because I haven't been able to open up the thing.
I'm still interested... has anyone else opened up one of these and repaired it? Thanks again,
Andy |
What type of compressor is it? is the black box type or the cream colored one. If it's the black box, pry it open and check the electrical connections on the switch. They sometimes loose connection.
The Fox Carrera |
This compressors are very similar to those that sell at $10 at Pep Boys, Wal Mart, Wester Auto, etc. Open it and try to find one similar cheap compressor and fiz it in the Porsche compressor box.
TIA
Andy |
Just the obvious....Check all the solder joints at the switch and power input. That switch is not the best quality.
The Fox Carrera |
Sorry, I meant any tips getting the darned thing open...
Thanks,
Andy |
OK I fixed mine. I have the black box air pump. I pried it apart with a screw driver. The tabs are in the exact middle of all four sides. I looked first at my switch and it looked fine, and was hooked up to both wires. Then I noticed a small spring out of place. I looked around and saw one small spring in place. So I put this adjacent to it on the other side using a small screw driver. I then put it back together and took it out to the car. I plugged it in and turned it on and it worked.
Hurray........
The Fox Carrera |
