svonkampen's Avatar
How do you open the door from the inside with RS style door panels?
Ok.......I know ......embarrasing question.....
I'm wondering how does one open the door from the inside with RS Door Panels installed.....
Is that what that red string is for?
SvK
Old 06-22-2004, 10:21 PM
}{arlequin's Avatar
um... pull the string
dave
1973,5
Old 06-22-2004, 10:28 PM
svonkampen's Avatar
rrrriiiighhhhttttt
SvK
1996 993
1968 911L 3.0 Carb'd.....(sold)
"I don't even know enough to know that I don't know."
Old 06-22-2004, 10:38 PM
The installation of RSA door panels necessitates the use of the "Bo & Luke" ingress/egress method.
Old 06-22-2004, 10:52 PM
Binge User
Schrup's Avatar
Isn't that Kid Rock?
Paul
Old 06-22-2004, 11:03 PM
ScottKelly911's Avatar
Send a message via AIM to ScottKelly911
hahaa ok, obviously you are a newbie so I will be the one to explain it to you as I have RS door panels. They are actually not just strings, they are Straps. They're about an inch wide and depending on who they're from, about 2 inches long. You simply pull on the strap and the door opens, just as if you pulled a latch. The reason for this, is to save weight. Though the actual ommission of the mechanism and latch don't save much weight, the collaborative loss of door pockets, regular door handle and opening latch does save quite a bit of weight, now multiply it by 2 for each door, you're down about 15 pounds or so.
Scott aka Mouse
Gruppe B #22
Current: Biarritz White ‘01 996 Turbo GT2 look & 1972 Targa Carrera RS Clone w/3.6
Past: ‘75 911, ‘75 914, ‘76 914, ‘66 912, ‘68 912 & ‘01 Arctic Silver 996 Turbo
Old 06-23-2004, 01:10 AM
Langers's Avatar
Just don't try to close the door by pulling on the strap. You'll get extremely frustrated!!
2004 VW R32 - B road bahnstormer
1992 Peugeot 205 - Tarmac rally weapon (well eventually...)
Old 06-23-2004, 01:20 AM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
also learn to use your elbow to push on the door as you pull the strap.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 06-23-2004, 02:23 AM
SvK? You have an early car don't you? If so, you need the early RS door panels, not the RS America panels with the short pull straps. Here's the early panel:
Old 06-23-2004, 03:26 AM
thrown_hammer's Avatar
The early panels AKA "RS door panels" like Curts, not "RSA door panels"(with the big loop pull strap) Look much better in the early cars. IMO.
You pull the long black strap in the above pic to open the door and pull the small black handle above it to close the door.
Keeper of the Titanium Monkey
1975 911S (sold)
1973 911 w/3.2 (sold)
1983 911SC targa (sold)
Looking for a 987.2 or 981 Cayman
Old 06-23-2004, 05:46 AM
}{arlequin's Avatar
Except that in my case the little black handles are sheiss. Don't know what "brand" they are, but they are both broken and you either pull the door shut by the long "opener" strap (and let go quickly) or, since it's warm, with windows down it's rather easier.
Creating/installing new handles has already been scheduled as this weekend's project. (And a small "big idiot light" for the oil)
P.S. has anyone else experienced the broken door handle problem or do mine just happen to be made from the most brittle plastic ever?
dave
1973,5
Old 06-23-2004, 06:54 AM
Those cheap-a$$ plastic handles are the same as the originals, made by Fiat. Lightweight, not durability, was the only consideration. They break easily. I've found the best way to shut the door is to pull with the plastic handle - then let go and allow the door to swing closed.
Old 06-23-2004, 06:59 AM
I got mine from AppBiz. The first time I shut my door the handle came off in pieces. A new handle was sent no questions asked. No problems since. When I inspected the broken handle it was full of air bubbles. So I believe it was just a faulty handle.
1975 911S (sold)
Old 06-23-2004, 07:02 AM
}{arlequin's Avatar
I haven't taken the door apart yet, but to make the handles and attachments bulletproof, I will. Is there anything tricky to removing the panels or is the procedure as simple as it *appears*? (I've done the search, read someone's informative 912 website etc, don't remember anything unusual in the procedure, just trying to verify.) Also, are the handles attached to some bracket on the inside or are they just simply screwed into the panels?
-sorry for the hijack
dave
1973,5
Old 06-23-2004, 07:10 AM
Removal would be pretty straight forward. The appbiz handles are anchored thru the panel and into the door.
1975 911S (sold)
Old 06-23-2004, 07:16 AM
}{arlequin's Avatar
thank you
dave
1973,5
Old 06-23-2004, 07:17 AM
My RS strap on the passenger side pulled out at the forward mounting screw. Passengers tend to pull toward themselves as opposed to toward the front of the car which makes pulling the screw out pretty easy.
Do you guys mount the strap screws to the panel or completely into the metal door frame?
"Rust never sleeps"
Old 06-23-2004, 10:13 AM
The strap screws into a factory bolt hole location on the door with my panels.
1975 911S (sold)
Old 06-23-2004, 10:15 AM
Thanks. I haven't bothered to take it off to get a good look. The PO installed these and it looks like he used drywall screws.
"Rust never sleeps"
Old 06-23-2004, 10:16 AM
Originally posted by MikeSid
... The PO installed these and it looks like he used drywall screws.
heh.. probably the same guy that installed my headlight bezels, 3" deck screws!
'73 RS Clone (flared, lowered, backdated, swapped)
'72 124 Spider (newest project; shaved & lowered cruiser)
'97 328ic (wife's toy)
'05 3500HD D/A (tow vehicle)
Old 06-23-2004, 11:05 AM
