Fuel line replacement
Hi Pelicans,
I have read the many subjects on fuel line replacement but couldn't find anything particular on the fuel lines running from the fuel distributor to the injectors. I have a 1978sc with the nylon fuel lines. The fuel lines itself look pretty good but the outer rubber protection hoses around it look pretty worn especially on the left. My question is how do I go on replacing these, before I damage anything by doing it in the wrong sequence. Would you advise upgrading to the metal fuel lines and where can I find the necessary parts on our hosts website? Thanks again and have a nice Sunday, Regards, Gerko 1978sc |
your plastic lines are almost 30 years old. i would just get the same ones and not worry about it.
here you go, from pelican. http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_fuelCI_pg4.htm#item15
poof! gone |
Re: Fuel line replacement
Lots of good reading here: http://forums.pelicanparts.com/search.php?action=showresults&searchid=732599&sortby=lastpost&sortorder=descending
