Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
H.G.P.'s Avatar
Can't get the CV boot over the cap/flange. Photo
Tried and tried and do not want to tear it...can't get it over the cap.
1969 911 E Coupe
"Little Bull" "Horse"
"H." Heart, "G." Gears, and "P" the Porsche
Old 06-27-2004, 01:02 PM
H.G.P.'s Avatar
This is as far as I can get it. What am I missing here?
1969 911 E Coupe
Old 06-27-2004, 01:06 PM
The best way I have found to do this is to get the boot on the flange before you put it on the driveshaft. My procedure is as follows:
1. Install boot on flange.
2. Slide small end of boot over driveshaft.
3. re-install CV joint onto shaft.
4. push flange back on CV joint.
5. insert retaining clips onto boot ends and driveshaft end.
6. Install on car.
I hope this helps!!
Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood.
Ayrton Senna
1993 964 RS
Old 06-27-2004, 01:11 PM
are you installing or removing? if youre installing wrap the splines in
electrical tape and grease it up. worked for me. if youre removing, whats the point? buy new ones and rip the old ones off.
oh yeah and what ever the case remove that cv joint off the boot before doing anything
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 06-27-2004, 01:36 PM
oops our boots are not alike. scratch that, i see the problem.
hmm, try really small pliers with the ends wrapped too get that
last little bit around.
Jason
81 SC
97 328is
Old 06-27-2004, 01:39 PM
i clamp the cv in a vise, (across the diameter), tap the metal flange on, then use a dull hooked tool to work the boot in place. it is a PIA, but you get better at it after doing a couple. then tap the flange off the cv after installing the clamp, and put the boot/flange onto the axle shaft first, followed by the cv.
jwworkshop@aol.com 206 789 6800
7613 greenwood ave n seattle wa 98103
Old 06-27-2004, 03:11 PM
Kantry Member
oldE's Avatar
I just did this the other week-end. As James said, fit the boot to the flange first. I used a little silicon spray to lube the inside of the boot, then gently stretched it on over the flange. Then work the boot onto the axle shaft and install the CV joint. Should only take a minute or so.
Les
"Emerson, there's an easy way to get rid of the understeer. Just use more throttle." Jochen Rindt
Old 06-27-2004, 03:31 PM
rs911t's Avatar
The only success I've had is as the others have said - before the boot/flange assembly is on the axle. It's impossible once they're on the axle and full of grease. Infuriating, to say the least. Had two pop off yesterday during an engine drop.
Greg
1972 911T
TrackVision
Old 06-27-2004, 03:36 PM
Randy Webb's Avatar
Won't the boots with the built-in flanges fit your CV's?
IF not, or if you are determined then use the dull hook or padded pliers methods above.
Good luck.
Old 06-27-2004, 04:13 PM
H.G.P.'s Avatar
They are on! I don't exactly know how, but I followed the consensus, and put them on with the flange/cv off the axle. Like they had to be "worked over" the top, the last edges a REAL PAIN..to the hands, and I used gloves
1969 911 E Coupe
Old 06-27-2004, 06:04 PM
Fantastic!!!
James
Ayrton Senna
1993 964 RS
Old 06-27-2004, 06:13 PM
rs911t's Avatar
Greg
1972 911T
TrackVision
Old 06-27-2004, 06:26 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
