Porsche engine rsr
Any person know what type engine would use a 911/72 internal engine case number? For example 911/83 is a carrera rs . What would a 911/72 be ? Engine has Bosch distributor twin plug , high butterfly Bosch fuel injection rsr flywheel
Old 01-31-2023, 06:55 PM
That should be a '72 RSR engine. 3.0 (10.3:1) 300hp.
Old 01-31-2023, 07:13 PM
The 9 Store
Sure is pretty.
All used parts sold as is.
Old 01-31-2023, 07:47 PM
Registered Minimalist
75 911s's Avatar
high butterfly MFI is the shiz
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 02-01-2023, 06:08 AM
Need more pictures, but the injection pump is not a race pump and doesn’t have soft mount with support rod. Center cam oil system is modified, small fan appears to be present, nice setup, but doesn’t appear factory.
Old 02-01-2023, 07:48 AM
send it to me. I will test for you free of charge,.....
Old 02-01-2023, 08:03 AM
Bill Douglas's Avatar
Sounds like it would bolt straight into a 911 SC
Old 02-01-2023, 10:04 AM
H-viken's Avatar
They made a 3L already in 1972? Would be the first one I’ve heard of
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 02-01-2023, 11:15 AM
75 911s's Avatar
From the Red Book:
1972 911 RSR
92mm bore X 70.4 Stroke 2.8
MFI
10.3:1 compression
308hp at 8k
217 ft lbs at 6200rpm
Old 02-01-2023, 12:20 PM
It's a 914 ...
stownsen914's Avatar
First RSRs were '73 and 2.8L, 911/72.
Old 02-01-2023, 02:21 PM
gearhead
92 x 70,4 2808cc 308hp
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 02-01-2023, 03:23 PM
