Cruise controle
My cruise controle is not working (95 993) where could I start looking?
Tks |
-fuse
-micro switchs at the clutch pedal and brake pedal
max |
here, this should keep you busy
max |
Tks....
If you have to buy parts to repair you would be better off buying one of the $100 Audiovox universal kits and use your existing column control to control their parts. Pretty straight forward if you can use a circuit tester.
Try Pcar club and Ebay for the parts you need, prices are out the roof for the OEM replacements.
DonMo 1984 911 Carrera Targa 3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip Columbia, SC "Go Hokies" |
Still didnīt have time to check but if I need to replace will look....tks
