Swepco automatic trans fluid in 915?
My garage has told me they prefer swepco automatic transmission fluid (714 I think) in the 915 tranny. The owner who races his P cars swears by it. Any thoughts on this.?
Thanks, Graham
"Penelope" 1980 SC Targa in Grand Prix White |
Semper drive!
For the 915 tranny, Swepco 201 is the preferred choice, from what I have read here.
Randy
84 944 - Alpine White 86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )One Marine's View Igitur qui desiderat pacem, praeparet bellum |
I would think that ATF would kill the tranny. It's very low viscosity compared to the regular tranny fluid.
Jerry Kroeger
82 911SC Targa (05 Boxster S ) gone, but not forgotten 87 Suzuki GSXR-1100 1953 MG TD Mk II |
Something is not right with that advice. Are you sure?
Your ring and pinion would cook, IMO. |
ATF is more of a hydralic fluid right? not really a lube.
poof! gone |
Isn't ATF something on the order of 10W?
Marv Evans '69 911E |
Eugene (Formerly) at Pelican Parts Pelican's E-Commerce Guy, 2003-2011 2001 330i Sport 1983 911SC Coupe (sold) |
Look at the manual. 915's require lube to API- Grade GL- 5 spec, specifically in 75-90 weight gear oil. Some gear oils ( like most redline) is rated GL-4..would cause high pinion loads and rapid wear.
I doubt auto trans fluid has these properties.... ---Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
thanks
Thanks....Just bought some 201 from our host.
Graham
ATF is used in some conventional gearboxes with Borg-warner type synchronizer rings for reduced drag and fuel economy reasons ... but NEVER, EVER in transaxles or rear ends with hypoid gears!!! To do so is PURE LUNACY Porsche-patent synchronizers are much more critical than Borg-warner synchronizers ... with respect to lubricant qualities, and contaminants in the lubricant!
Some FWD cars use it [or motor oil] in their transaxles, but they don't contain hypoid gears, remember! Mfrs aren't concerned about long-term life when they make those lubricant recommendations in the name of fuel economy ... after all, HonDatToys are just disposable commodities!!! [paraphrase credit to the late Harry Pellow]
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
