homemade p225 tool for 901 dog ring removal
Hi, in case this helps anyone else down the line... it seems like the p225 tool is backordered everywhere, so I made my own.
- 1/4" steel plate from home depot cut in half
- on a drill press, 2 3/8" hole saw with pilot drill down to about 1.5mm from cutting through the plate
- switch to 2 1/4" hole saw using the same pilot hole and cut all the way through
- cut the plate in half once the hole is drilled through
Works great! I just used a large socket and hammer to drive the gear out over a vise. I'll weld some tabs on later so it can be bolted together, but it worked fine as-is.
Old 03-01-2020, 07:48 PM
Slippery Slope Victim
NY65912's Avatar
Nice! Man after me own heart, if you ain't got it make it!
MikeČ
1985 M491
Old 03-02-2020, 03:49 AM
