-   -   lets see 911R style deck lid mesh! (http://forums.pelicanparts.com/porsche-911-technical-forum/169864-lets-see-911r-style-deck-lid-mesh.html)
thrown_hammer 06-28-2004 12:21 PM
I am contemplating replacing my heavy decklid grille with a fabricatted 911R style grill. Show me pics. What do you use for material....how is it attached? Minkoff's car comes to mind. Help a Lightweight Junkie out. :D
}{arlequin 06-28-2004 01:04 PM
only bob tilton comes to mind... while you're at it, ask him some other questions so he posts other pics of his car too, not just the grill
KobaltBlau 06-28-2004 01:13 PM
well said dave! I want to see more pictures of bob tilton's car too!
Also, that "912R" somebody built had the screen setup.
edit: my "somebody" is John Thornton.
svandamme 06-28-2004 01:49 PM
so what kind of weight loss are we talking about here?
wouldn't that be kind of futile with the stock decklid? i mean, i suppose the lid would be the heaviest part of the assembly , not the grille?
Rot 911 06-28-2004 01:58 PM
You are going to die if you don't use the stock engine lid grill!:D
vash 06-28-2004 02:01 PM
bob tilton definately has it "goin on". let him get some pictures up.
thrown_hammer 06-28-2004 02:05 PM
I have a F/G duck not a heavy steel decklid. I have to make up for the weight I added with the deathcage. Ditching the Recaros and adding the Momo RSGT's with Billet aluminum mounts helps. But I still have a ways to go.
Ove 06-28-2004 02:10 PM
thrown_hammer,
I want to do the same on my car. But since I have an early turbo tail I will place the grille on the outside, not under the decklid.
The material you need is used for grille/bumper inserts.
I found the a black painted aluminium grille I wanted in my local car stereo shop.
Try something like this: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7907758376&catego ry=33645
Here's the 912R
http://forums.pelicanparts.com/uploa...1088456947.jpg
http://faculty.haas.berkeley.edu/snow/cars/porsche/wheels.html
Randy Webb 06-28-2004 02:18 PM
I would also like to find out how much Al grid materials used here weigh.
Here is an odd tidbit - both the stock plastic and earlier Al bars weigh the same - and are rather heavy. You might be able to save a lb. or so with an Al. grill.
The grill is something that cries out to be made of CF..... would also look nifty.
KobaltBlau 06-28-2004 02:23 PM
seems like this would be a pain compared to laying up a big panel for a flare or something; each slat would have to be made separately. I guess you could lay up a big square, cut it into strips, and bolt them together with plastic spacers in between.
That setup on the 912R looks rather easy to do though...
}{arlequin 06-28-2004 02:38 PM
That really cracked me up! LOL thanks.
That seafoam (?) car is cool. I've never seen it before. As for the fabrication of the cf grill by the factory, I'm not so sure about that. Historically, they probably put as much thought into the mesh grill as into those R lights. Which is to say, not very much. As long as it did its job, *rudimentarily* at best, that was enough. At the time, they probably just slapped something on, as long as it was light (and functional for the duration of the race.)
All that above is meant to say that as far as the rough-but-fast-factory-race-car look is concerned, I like it. A lot.
Jack Olsen 06-28-2004 02:41 PM
I can't see why carbon fiber would be a plus for a screen. You don't need any strength at all from the application. I'd think temp-resistant plastic or lightweight aluminum would be the way to go.
bob tilton 06-28-2004 02:41 PM
i guess i'll chime in here due to the kind words - thanks! i copied the emory built 912R owned by thornton. i later found some vintage pics in the book"63-71" with the exact same grill which is cool cause it makes it "period correct" ;).
i bought a beat up 3 bar (vs 5 bar) grill for around $5 from EASY. removed all the rails, removed the outside bars (retaining the center bar), painted it satin black, turned it upside down and mounted it to the decklid. very easy - very cheap - very light.
the R grill is a bit different in that it is incorporated into the firberglass decklid without any mounting hardware. the "grain" of the mesh is also different from the production grills. the diamond shape runs from the top to bottom rather than side to side.
it's funny that this topic got started today. i meant to go to yardbirds after seeing a nice screen that i wanted to try. got too busy in the backyard. it comes in 4' x 8' sheet. it is very close to the screen i have been looking for.
bob tilton 06-28-2004 02:45 PM
ps kurt zimmerman also has a cool decklid grill.
Ove 06-28-2004 02:56 PM
http://forums.pelicanparts.com/uploa...1088459760.jpg
http://forums.pelicanparts.com/uploa...1088459791.jpg
Randy Webb 06-28-2004 03:12 PM
Jack, My thought was that CF would be lighter than the stock plastic.
I agree re the Al grid (tho the sotck Al bars are surprisingly hefty).
Randy Webb 06-28-2004 03:15 PM
}{arl, I'm thinking of something as nice and finished looking as the stock unit - I agree re making one long strip and cutting it. I don't if it would be lighter - but it ought to be.
Zeke 06-28-2004 03:25 PM
Due to the hardware within; spacers, rods, etc.
The screen is the business. Get a 914 lid for cheap and cut up the screen. It's a nice flat diamond, not expanded metal like plaster lath. I believe it's steel, though.
126coupe 06-28-2004 04:08 PM
here you go outside mesh is powder coated alum the inside is fine mesh from pegasus racing I run open stacks w the webers therefore the fine meshhttp://forums.pelicanparts.com/uploa...1088464102.jpg http://forums.pelicanparts.com/uploa...1088464126.jpg
Randy Webb 06-28-2004 04:45 PM
Minkoff - how'd you do the surround - tubular looking thing that makes it look so nice?
Zeke - Thx. 914 lid eh? I like the idea - maybe now the sheet metal place in town won't see me oggling his diamond mesh all the time...
126coupe 06-28-2004 04:48 PM
Its just some profile rubber, Pep Boys or for more of a selection Pegasus Racing products
goat 06-28-2004 04:58 PM
I didn't want to say this earlier but the dimond mesh does look like the stuff I put over my rain gutters, just wider. Is the paint coating the only difference?
geof33 06-28-2004 05:37 PM
To the race/lightweight guys... Thrownhammer, and Bob T. specifically...
Where did you get the hinges you're using on your decklids? I need a set of those for my RSR project...:D
Jim Garfield 06-28-2004 05:47 PM
http://forums.pelicanparts.com/uploa...1088469774.jpg
This is the Toad Hall R that was at Rennsport.
126coupe 06-28-2004 05:48 PM
I agree the diamond mesh on my R clone is kinda Home Depot-ish
The powder coating helps but when I did that it was 6 years ago( just learning) ( more experience today) if I ever re do it Pegasus racing carries mesh thats does not have that "construction" material look to it, for my applicaton you need to use spacers to keep the mesh from having that wavy look to it
Jim Garfield 06-28-2004 05:52 PM
http://forums.pelicanparts.com/uploa...1088470232.jpg http://forums.pelicanparts.com/uploa...1088470280.jpg
An ST, and the Targa Florio winning RSR. Interestingly all three are factory items, yet very different execution.
trj911 06-28-2004 08:02 PM
Geof33- Re: deck lid hinges. Shawn had those made up out of titanium. He was working on a deal to have more made but it fell through. I'm sure he'll chime in here with the exact scoop.
Shawn, I like the clean look of the grill on the white 911R from Toad Hall. Nice clean straight edges. You might even save an oz. or 2 by trimming off the flanges used for fastening the old grill in place.
I hope you have a safe color in mind for this thing!
Randy Webb 06-28-2004 09:36 PM
Here are wts. for the stock grill (lbs.):
Engine lid grill, 1975, plastic 2.4
Engine lid grill, 1973, metal 2.5
These are accurate wts. determined using a NBS traceable scale.
thrown_hammer 06-29-2004 05:08 AM
Hey guys. Thanks for all the pics! So I gather that you just take a stock grille and remove the slats? Thats easy enough. Or I could get fancy and fab something up out of expanded aluminum....
As for the hinges. I made about 6 sets out of Titanium. They are welded grade 2. Weighing 2 ounces a set. I sold them to Pelican heads. I ended up keeping one set for myself. I am not sure where Mr. Tilton got his set.
I do like the Toad Hall R grille. But if I cut the tabs off then I have to paint again.....I dont like painting.
klaucke 06-29-2004 06:20 AM
A friend of mine has used the home depot stuff on his Saab, it looks and holds up great.
Zeke 06-29-2004 07:42 AM
Well, there's some flat dia mesh and then there's expanded metal that purposely has a "grain" to it. sharp edges too. Your sheet metal shop may have the same as the 914 or close. It's just that I've seldom seen a 914 lid sell for more than $10.
Almost all it can be had thru McNichols catalogue including Mark Minkoff's fine mesh and at much less in price than Pegasus.
thrown_hammer 06-29-2004 08:25 AM
I think I will use expanded aluminum mesh and use Titanium strips for support on the ends and in the center.....
bob tilton 06-29-2004 08:34 AM
those are some cool pics garfield.
i remember when my car was in the body shop a guy brought some screen in to install on his aftermarket f/g bumper. it was a very close match. i believe he picked it up from a "ricer" shop which means he probably paid good money for it...i don't know.
i don't have R hinges for my decklid. had a set from gt racing and sold them. the ti hinges looked great.
andyjboy 06-29-2004 02:26 PM
geof33 asked:
I still have a couple of sets left from the current batch :
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/152062-911r-engine-lid-hinges.html
Andy
typ550 06-29-2004 02:40 PM
Milt's right on about McNichols. I have had good luck with them as a source for mesh/wirecloth products for my car projects. If there is a distribution center in your area (there is one here in ATL), you can see samples in their showroom. I believe they will also send samples by mail...
Flojo 03-02-2020 02:43 AM
R-inspired grill with 3D mesh. 750 gram unit (Aluminium).
All hand made (except for laser cutting the base frame)
the frame is bent in shape on an english wheel, bores are sunk, mesh is crafted into shape to fit the inserts, custom bushings hold the frame flush with lids edge
https://up.picr.de/37870227mx.jpeg
https://up.picr.de/37978247rl.jpeg
