Bushings: poly-carbonate vs. poly-graphite
I'm thinking about replacing the (probably original) suspension bushings on my '75 911S.
I've settled on using OEM rubber or monoball for the rear trailing arms, but I'm up in the air about which material to use for:
-Rear springplates (Neatrix rubber, poly-carbonate, or poly-graphite)
-A-arms (poly-carbonate or poly-graphite).
What exactly is the difference between poly-carbonate and poly-graphite?
Thanks,
Colin
Old 06-29-2004, 09:11 AM
I have the Neatrix spring plate bushings, and I'm not that happy with them. This winter I'm going to upgrade, most likely to the Poly-bronze elephant bushings.
I have the Weltmeister 'race' bushings in the front, and I like them, but I'll probably upgrade them as well.
Old 06-29-2004, 09:22 AM
some guys don't like transmitted street harmonics.. some guys don't mind. Calif roads are relatively smooth.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-29-2004, 09:30 AM
KobaltBlau's Avatar
Colin, are PolyBronze out of the budget?
Andy
Old 06-29-2004, 09:38 AM
Thanks for the replies,
I just can't justify the price of the polybronze on this car. I know they're the best, but that's the bottom line.
I'm trying to figure out what's the next-best - polygraphite, polycarbonate, or neatrix?
Old 06-29-2004, 09:41 AM
Certified Pre-Owned
BGCarrera32's Avatar
I did soft poly, which a year ago anyway was available from Pelican. Its somewhere between the factory rubber and all out rigid. The fit was obnoxiously tight and I had to bore the i.d. out on the lathe before the bushing would slip on. I also cut in a grease channel and added a zerk for lubrication. There is an article in this months (I think it was this months) copy of Excellence where they did something similar with the hard poly bushings on a 911. All in all they have worked well, but for the farting around and labor hours you're probably money ahead with the Elephant poly bronze setup.
'84 Carrera Coupe
Old 06-29-2004, 09:50 AM
KobaltBlau's Avatar
OK. That's completely fair. I'm not sure what the next best is.
Andy
yep.. Elephant Man's bushing are a class act. I've had the Welt bushings on a street 911 since before Elephant Racing was born.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-29-2004, 10:15 AM
Bump - already off the front page
Anyone know the difference between polygraphite and polycarbonate bushings? Wear? Noise? Durability?
Old 06-29-2004, 02:13 PM
KobaltBlau's Avatar
I probably just don't know much about bushings, but Lexan is a polycarbonate. Those "nalgene bottles" in the harder plastic are made out of lexan. This seems like a pretty rigid (even crackable) material for bushings. Delrin is more suitable for rigid bushings...
Where are you seeing polycarbonate bushings?
Andy
Old 06-29-2004, 02:21 PM
I was just kind of surfing around Pelican and saw these:
(1974-89) Front Suspension A-arm Rear Bushing, Poly-Carbonate (sold per each, 2 req. per car), 911/911 Turbo/912E (1974-89) [Photo]
PB-012R $13.75
Front Suspension A-arm Front Bushing, Poly-Carbonate (sold per each, 2 req. per car), 911/911 Turbo/912E (1974-89) [Photo]
PB-012F $13.75
Front Suspension A-arm Bushing Kit (Set of 4), Poly-Carbonate, 911/911 Turbo/912E
Old 06-29-2004, 02:34 PM
KobaltBlau's Avatar
Hmm, maybe a pelican staffer can clarify. Betcha they're really polyurethane.
Andy
Old 06-29-2004, 02:38 PM
Chuck Moreland's Avatar
Not a staffer, but the listing is a typo. Those are polyurethane bushings.
Nobody makes a polycarbonate bushing. Polycarbonate would be a poor choice for bushing material. Fitment would be even more problematic than the current crop of polyurethane bushings.
Polygraphite is made from graphite impregnated polyurethane. The graphite is an effort to reduce the squeaking problems so common with polyurethane bushings. It may provide some marginal improvement, but can still squeak.
Chuck Moreland - elephantracing.com - vonnen.com
Old 06-29-2004, 03:04 PM
Az911's Avatar
Send a message via AIM to Az911
Don't be cheap when it comes to suspension. You are willing to spend the extra few dollers for the rear momoballs do the same for the front and go polybronze
72T RS look
96 993
Old 06-29-2004, 03:20 PM
Ah-ha! Thanks for clarifying, guys.
AZ, I know where you're coming from, but $38.95 vs $237.50 is over my threshhold...I'm trying to be realistic about the car's value, use (90% street, 10% DE), and bang-for-the-buck.
I know many others see it differently and I greatly respect Elephant's products.
Colin
Old 06-29-2004, 03:23 PM
KobaltBlau's Avatar
Thanks Chuck, that's what I was thinking.
Andy
Old 06-29-2004, 03:42 PM
dickster's Avatar
colin,
i agree, if cost is an issue why bother with monoballs?
i went with neatrix in the rear - i wish i had done ploybronze, but if cost is an issue i would stick with neatrix.
the fronts are a problem. the poly's are a pain to fit properly - i opted for polybronze.
btw-polybronze are fairly new on the scene (?) so while they are very well made, durability remains an unknown - unless anyone can share any info that confirms their longevity.
Rich
'86 coupe
"there you are"
Old 06-30-2004, 12:27 AM
