-   -   Spring Plates - Interchangeability (http://forums.pelicanparts.com/porsche-911-technical-forum/170153-spring-plates-interchangeability.html)
Jandrews 06-29-2004 09:43 PM
Hello,
Does anyone know if the factory adjustable rear spring plates from an '88 Carrera will fit a '70 911 Coupe? I thought I read somewhere that the spring plates are the same from '65 - '86, but were changed for '87 and beyond.
Same question for rear sway bars. What years are direct bolt-on interchangeable?
Can anyone help?
Thanks,
JA
kstylianos 06-29-2004 09:47 PM
No, they wont fit as the t-bars in the G-50 Carreras are longer and the t-bar tubes on the spring plates are longer to accomodate. If you fit longer t-bars then, yes.
Randy Webb 06-29-2004 10:12 PM
Best to go with a little earlier car for a donor - then it's a common upgrade. I used a '77 I think. Anything before 87 shold work fine.
