-   -   No Spark (http://forums.pelicanparts.com/porsche-911-technical-forum/170161-no-spark.html)
911carrera 06-29-2004 11:21 PM
No Spark
Hi Pelicanheads, 87 carrera coupe 3.2
I recently had a intermittent no start/no spark,I checked previous threads and checked motronic ignition circuit,all inputs within specs
speed and ref sensor producing a/c voltage and has a good wave signal patterns,power to coil,injector pulses good,but no pulses at negative side of coil.I believe the brain is not grounding the coil circuit.Does anyone have a extra DME unit that I could try,I live in san jose,CA.I will pay a fee,or if anyone has one for sale.any replies appreciated.:(
Early_S_Man 06-30-2004 03:05 AM
Robert,
Sounds like it could be a cracked solder joint at the coil driver transistor ...
Wayne mentions it in the following article:
http://www.pelicanparts.com/bmw/techarticles/E36-DME-Repair/E36-DME-Repair.htm
911carrera 06-30-2004 10:07 AM
no start
Hi, Early S Man
Do you have a pic of what a coil driver transistor looks like.Also have you ever heard of a ECM Rebuilder named full logic/control systems,they charged $319.00 to rebuild a computer,they are located in Whitney TX, on 952 state hiway 22 ,Whitney,TX,76692 #1-866-622-2959.
If anyone heard of them,are they a reputable company,any replies appreciated.Thanks for the DME info article Early S Man:confused:
