-   -   cylinder not firing - how do I find it. (http://forums.pelicanparts.com/porsche-911-technical-forum/170265-cylinder-not-firing-how-do-i-find.html)
Rouxzy 06-30-2004 01:20 PM
I have a cylinder that is not firing. I know this because the car is running rough and it seems as though fuel is running right to the exhaust because I leave a trail of white smoke behind. This originaly happened just now and then, now it is constant. The car is in the garage until I fix the problem. Any ideas on how to find out which one is not firing?
Tom
David 06-30-2004 01:29 PM
Spray some light oil on the headers pipes were they exit the heads. It should be obvious which one is cold.
A Quiet Boom 06-30-2004 01:30 PM
Or, pull one plug wire at a time until you find one that makes no difference in the way the car runs. Use a heavy glove so you don't get a jolt!
EDIT: oops SoCal beat me to it.
Rouxzy 06-30-2004 01:33 PM
Thanks guys I'll give that a try.
Tom
stlrj 06-30-2004 02:10 PM
If you prefer not getting zapped you could back off each banjo fitting leading to an injector at the fuel distributor with a 12mm box end wrench.
This will cause a slight fuel leak at the fuel distributor but not a significant problem.
Cheers,
Joe
vash 06-30-2004 02:15 PM
no, once you start the car, spray regular water on the headers. the dead cylinder will not immediately steam the water. work sorta fast, because the heat will travel to the dead cyl from the good ones and mask everything. disconnecting plugs works but the water is do friggen easy, why bother.
gshase 06-30-2004 02:23 PM
After a short run time ( one or two min ) rub the exhaust stack with a crayon or the edge of a credit card. Crayon melts around 140*F while the credit card melts around 350*F. All should melt at the same rate, if not that is the bad one.
vash 06-30-2004 02:44 PM
old time motorcycle guy showed me that trick. best mechanic in the world. he got shot in a drive by in oakland, while gassing up. i pass his tip on, in his honor.
cliff
ChrisBennet 06-30-2004 05:08 PM
I had a bad injector once and I tried disabling one cylinder at a time to find the bad one. It was far from obvious. I was surprised how subtle the difference was.
-Chris
Zeke 06-30-2004 06:52 PM
-Chris
No doubt. Sometimes you have 1 1/2 cyinders out. That's real fun. I like the water idea. That would even show a weak one.
Jens 06-30-2004 07:26 PM
Cheers,
Joe
Yikes!:eek: Gasoline?!!:eek:
dean 07-01-2004 04:01 AM
You could take the plugs out and look and see which one is wet, if it is an ign. problem. If it is a fuel problem then that won't work.
I also wouldn't crack the banjo bolts. That would disturbe the sealing rings possibly
Dean
Cornpanzer 07-01-2004 04:49 AM
similar thought, but just wet your finger and see which pipes dont sizzle when you quickly touch it with your finger. Always works for me.
Rouxzy 07-03-2004 09:59 AM
Well,
I went the route of taking out each plug. They were all grey in color except for #2, it was black as coal. I check the resistance of the plug wire and it measured the same as the rest. I put in a new plug and it runs much better but still rough. I feel I have a fuel delivery problem which caused the plug to foul.
Carl_Boehme 07-03-2004 11:07 AM
Injector leaking?
sammyg2 07-03-2004 01:11 PM
If it's ignition related you can simply snap an induction fired timing light on to each wire, one at a time.
If it isn't sparking you won't get s strobe flash. If it is firing cortrectly you will get the light to flash.
Onliest problem here is if the wire is grounding and arcing through something besides the spark plug you will still get a signal.
vash 07-03-2004 04:59 PM
sam, i did that once, and i got flashing from the timing light. but the badness was the plug. water bottle, you dont even need to jack the car up. set the water bottle on "stream".
