Fuse Panel Diagram or Picture
Does anyone have a diagram or picture of the fuse panel for a 1974 911 (Targa). I suspect that the previous owner may have put the wrong size fuses in some positions. I am trying to avoid going through the wiring diagrams to look for the correct amperage. I would like the easy route. Position #1-Red Fuse, or a picture would be nice also.
PorschePilot
74 911S Targa - High Quality 2.7 Rebuild and Full Body Restoration
MID9 Member
Beechcraft V-Tail Bonanza
(Fly'n high and low)
Old 07-01-2004, 09:39 AM
A little help here.....Please.
PorschePilot
MID9 Member
Old 07-01-2004, 12:26 PM
Bill Verburg's Avatar
'76 C3 is from top 5amp, 25amp, 25amp. I'm sure that yours is diffferent because of the different heater setup.
Other than that maybe someone w/ a '74 manual?
Bill Verburg
Old 07-01-2004, 02:41 PM
Is there a diagram in the owers manuel? I don't have one, but maybe someone could scan one for me.
PorschePilot
MID9 Member
Old 07-01-2004, 02:50 PM
Ove Ove is offline
911 driver
Ove's Avatar
Maybe this will help?
PIC needed PLZ: SC fuse box
http://www.pelicanparts.com/911/911_Parts/911_electrical_diagrams.htm
Ove
'77 911S targa
Old 07-01-2004, 02:54 PM
Sorry I thought you wanted the engine compartment fuses.
The front ones are listed on the back of the cover, is that still w/ the car?
Bill Verburg
Old 07-01-2004, 03:01 PM
P.87...pocket spec book for 74:
Doesn't say which end is "front" of car:
1-foglites 16A
2-license plate lites 5A
3- fr/rr parking lites right ... 5A
4- fr/rr parking lites, left...5A
5- low beam ,rt...8A
6-low beam, left...8A
7- hi beam, rt...8A
8- hi beam , left..8A
9- fr turn signal, rt...5A
10-fr turn signal left...5A
11-l/r stop lights, flasher relay, backups...16A
12- rear defog relay,blower, rear defog indicator lamp.. 25A
13-windhield wiper/ washer ...25A
14- sunroof, rear wiper...16A
15-Aux heater, cig lighter, blower switch indicator lamp...16A
16-power windows..25A
17-emergency flasher...16A
18- interior lite, clock, glove box lite, trunk lite...5A
Engine compatment:
1- sportomatic...5A
2- not connected.... ( -)
3. rear defog..25A
Relays in fuse box:
1. A/C....
2. Fog lites
3. Horn
--Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 07-03-2004, 01:55 PM
Straight shooter
Lapkritis's Avatar
1-foglites 16A
7- hi beam, rt...8A
Engine compatment:
1- sportomatic...5A
3. rear defog..25A
Relays in fuse box:
1. A/C....
2. Fog lites
3. Horn
--Wil
Sorry to raise the dead. I'm sorting wiring on my '74 and I can tell that someone has been in here before and moved wiring around. I'm looking for the correct specified color wire on each side of the fuse.
Fudged panel soon to be replaced with ATO blocks as soon as I have the information to proceed correctly:
Top/bottom
1-foglites 16A (White with green stripe / white with yellow stripe)
7- hi beam, rt...8A
Thank you,
Andrew
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 07-08-2015, 01:04 PM
Have you seen this ATO fuse panel that Pelican is selling ?
In my opinion the best design there is in the market actually.
No affiliation
New company and new products. 'Classic Retrofit' 911 Fuse Panel and CDI+ ignition.
Check the installation instructions also
http://www.pelicanparts.com/catalog/images/electrical/911-FPR_Installation_Guide.pdf
Old 07-08-2015, 01:30 PM
Jonny H's Avatar
Hi, I am the designer of the Classic Retrofit replacement panel. I have quite a few fuse panel pictures from installs so can hopefully help you through this mess. Actually, it doesn't look too bad but some of the wires are a bit suspect. I don't understand, for example, why the left hand wire is so thick if it is only a 5A feed!
Fuse 1 as you listed them is on the right. Numbering in the wiring diagrams is the same as your numbering.
The numbers stamped inside the fuse box lid on later cars correspond to the fuse way number on the fuse block itself, hence 1 to 3, 1 to 10 and 1 to 8. Your car doesn't have the left hand 1 to 3 block. Our replacement panel uses these numbers. If you fit it you will gain the left hand three fuses for use as you wish.
Old 07-08-2015, 02:37 PM
Straight shooter
Lapkritis's Avatar
Hi Jonny,
Thanks for the response. There definitely was some tomfoolery with the wiring on the panel. I suspect perhaps when the car was painted/restored in '91 that the body shop may have mixed up a few wires when moving the panel around. Many of the wires/screws still have the wax pen from the factory intact so those I suspect are okay. Regardless, when I bought the car in '12 everything more or less worked except for the clock in the dash. The few diagrams I have found in color out on the WWW don't jive with what I see on my panel which tipped me off that I should find a legitimate color diagram to reference during my switch to ATO. Why, also, are there 3 feeds into #17 but 15 and 16 are empty? Are they bussed together on the back side?
I've built more than one chassis/engine harnesses by hand and a few megasquirts from ground up so I'm not really intimidated by the prospect of tracing the entire harness out... I would just prefer to not pull my dash apart if I can help it in the process. If you have a known-unmolested '74 fuse panel picture (coupe) then that would be a help.
-Andrew
Old 07-08-2015, 04:28 PM
ROW '78 911 Targa
timmy2's Avatar
Factory '74 schematics, download, print, tape together...
https://www.dropbox.com/sh/s292jtsyvl6llw2/AABF-ofgMfoMltGa99Asphr5a?dl=0
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, Bitz kit EFI.
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-08-2015, 06:06 PM
Straight shooter
Lapkritis's Avatar
Excellent Dennis - thank you. I've downloaded and will go through in the coming days to check colors against my panel.
Old 07-08-2015, 06:56 PM
ROW '78 911 Targa
timmy2's Avatar
You are welcome. If you have any questions feel free to ask.
And remember, S=F... Thin lines between them means they are connected together in the back.
Dennis
Old 07-08-2015, 07:49 PM
fred cook's Avatar
Fuse panel info
If you will send me your email address, I will send you a schematic for your Targa. It shows fuse size and wiring colors. Send to p911sc80@gmail.com
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 07-09-2015, 02:17 AM
Straight shooter
Lapkritis's Avatar
Hopefully he hasn't been looking for 11 yrs!
Old 07-09-2015, 07:51 AM
ROW '78 911 Targa
timmy2's Avatar
Better late than never...
See what happens when you revive an old thread.
Dennis
Old 07-09-2015, 08:35 AM
Jonny H's Avatar
Originally Posted by Lapkritis View Post
Hi Jonny,
-Andrew
Assuming that the original 10 and 8 way blocks are the same throughout the years - then (using your numbering) they are connected on the back between:
5,6
7,8
11,12
13, 14, 15
17, 18
+ you have a brass link on 15 and 16 which effectively gets power across to 16.
Certainly on later cars, original wiring has crimped ferrules on every wire end. Other wire ends are foreign or butchered.
A few words about spade connectors:
If you are considering using ATO holders that have spade connectors, I would strongly advise that you use 'bare' metal crimps with a professional ratchet crimp tool and proper boots / heat shrink. If your crimp tool is from HF, throw it away right now.
Be very wary of the spade connectors with the blue/red built in insulation unless you are 100% sure that the tool you are using can make the crimp. You should be able to tug on the wire hard and it not come out.
If the crimps are not 'made' properly you are potentially introducing dozens of failure points into your car which will totally negate the ATO improvement. Although you may see this as salesmanship I can assure you it isn't. It is the reason we stuck with screw terminals on our design because most folks wont have access to proper crimp tools and they are expensive to buy.
Old 07-09-2015, 12:08 PM
Does someone have a diagram for an 82 SC? I have a couple stray wires hanging out near my fuse panel and hope to get them hooked back into their proper fuses.
1982 911 Targa, 3.0L ROW with Webers
Old 07-09-2015, 12:29 PM
ROW '78 911 Targa
timmy2's Avatar
Amazing what a title search will do...
See post 5 here:
Fuse diagram
Dennis
Old 07-09-2015, 02:11 PM
