CO2 Adjustment
Today was replace the fan belt day and adjust the a/f mixture using science and technology. The fan belt was a no brainer and voila no more slipping, no on to the second task.
I borrowed a friend's gasmaster CO2 analyzer. I have a 3.2 motronic based system so I know the O2 sensor has to be disconnected, I did that. I see in my Bentley that it is supposed to be adjusted to between .6 and 1% with sensor disconnected. My friend told me to run the analyzer out of the exhaust until I get a baseline of 2%, I assume that is normal outside air. My question is do I add the .6 to 1% on the 2% to get a new CO2 reading of 2.6 to 3% or just go to 1%. With the O2 sensor hooked up I get 0 to -.3 no matter what I do. I assume the DME is doing the continuous adjustments. Any wisdom is appreciated.
DonMo 1984 911 Carrera Targa 3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip Columbia, SC "Go Hokies" |
air is approx 2%, so you can/must cal the meter with fresh air. Do not add or subtract the 2% from your exhaust readings.
Are you measuring without a catalytic converter or before it?
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender Last edited by fintstone; 08-28-2004 at 09:51 AM.. |
No cat, I have ssi's and a Dansk two to one exhaust.
