starter continues to run
Hey Folks,
My car left me stranded in the garage (i guess i should be thankful). When I went to start it up, the starter seems to run after the car is started (the starter running continually prohibits the car from fully starting). If I rotate the key back to left to try to disengage the starter the car quits.
Initially I thought I had an key ignition or ignition switch problem. but after testing with another one I have the same symptoms.
I also removed the starter to insure the solenoid was engaging. After testing with the battery i could see the soleniod is in fact engaging.
Now I am at a loss. What stops the starter from running? What do I troubleshoot next?
Any help would be greatly appreciated.
Ned
79 911SC Targa
nedzaldivar@yahoo.com
Old 07-02-2004, 03:44 PM
