sushinav's Avatar
Where's "Z1" TDC mark on my 3.2?
I'm doing 1st valve adjustment on my 87 3.2 and looking for my "Z1" mark on the pulley (see Pelican valve adjust article), but there isn't one. I have 2 notches and the left one, when lined up, shows the rotor to be about 1/8 CCW off the distributor mark. The valves for #1 cylinder do give a wiggle. But with the distributor mark being a little off, and 2 unmarked pulley notches not being what I'm used to seeing, my confidence was low. Is this normal on 3.2and am I safe to proceed, or does this mean something is timed wrong. Car runs fine. Help.
Oh yeah, anyone else doing the 10-11 July DE at Willow?
...sick with gearheadia
Old 07-01-2004, 07:50 PM
fancytown
Here's what I learned: look at your distributor timing spec. If, for example, your timing is to be set at 5 degrees AFTER TDC, then the Z1 mark is to the right, or BEFORE, the ignition timing mark. This varied from different years, so don't believe people when the say it's to the right, or left.
Someone please correct me if I'm stretching here...
1989 Cadillac Brougham
1978 911 SC Targa w/ 3.0L to 3.6L to 3.2L conversion - sold
1972 911T Targa - sold
Old 07-01-2004, 08:02 PM
I used the left mark of the two as TDC, everything else was the same and it came out OK. Relax and take your time, it is easier than you think.
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Old 07-02-2004, 03:48 AM
thrown_hammer's Avatar
I need to do this in the fall. There is no Z1 mark???
Shawn French Honorary SOCG Member and Keeper of the Titanium Monkey
1983 911SC Targa Kelly Green
1961 VW Ragtop
2001 Xterra
1997 Jeep Wrangler "The Tick"
Old 07-02-2004, 06:14 AM
The Z1 engraving on the 3.2 pulley is very hard to see from the top. To find it, turn the engine clock wise, there will be 2 closely spaced marks on the main pulley, the first one is the timing mark Before Top Dead Center (BTDC), and the second one is the Z1 Top Dead Center.
That would be where 1 or 4 is at TDC.
Porsche 2005 GT3, 2006 997S
Exotic: Ferrari F355 Spider, 328 GTSi
Collectibles: 95 F355 Berlineta, 348TB Challenge
Disposable Car: BMW 530xiT, Audi A3S
Old 07-02-2004, 06:37 AM
I recently had the same question. John Walker's response to a similar query...
Finding TDC on 3.2...
Old 07-02-2004, 07:04 AM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
I had the same concern, here's the layout:
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 07-02-2004, 09:37 AM
kqw kqw is offline
Pull the cap off your distributor and you'll see a notch located on the lip of the distributor.
Turn your engine until the rotor points directly at this notch and look at the corresponding mark on your main pully and it should line up directly with a mark on the fan housing. That's TDC.
The Fox
Carrera
Old 07-02-2004, 09:54 AM
sushinav's Avatar
We still have 2 opinions on where the distributor mark should be. One says slightly off, one says right on. I know the Motronic handles the timing, but I just wanted to make sure the static timing was ok. Oh, and superb pic! The left mark is Z1, as I thought, but you helped confirm. Thanks for the help guys. Bottom line I guess is that cam overlap will allow us to set any valve that can be wiggled as long as you are near TDC on that cylinder.
Old 07-02-2004, 04:32 PM
UFLYICU
ZOA NOM's Avatar
My dizzy rotor is not pointed directly at the mark on the dizzy.
prc-racing.com
Old 07-02-2004, 05:48 PM
sushinav's Avatar
Rick,
Thanx for your pics and help. Jobs done, just gotta button it back up and I'm ready for Willow on the 10th.
Old 07-03-2004, 10:33 AM
The rotor will NOT be pointing directly at it. That is because the ignition will likely happen as the edge of the rotor approaches the wire pin location.
Old 07-03-2004, 11:37 AM
A Marchand fan before you
Por_sha911's Avatar
When I did my valves this spring I started to worry that the distributor wasn't exactly at the mark when I had the Z1 mark. The guy helping me said it was OK and the valves came out great. Use the Z1 mark on the pulley and the distributor will be close but not exact.
Joe
Old 07-03-2004, 07:51 PM
kqw kqw is offline
Maybe I got the perferct car....
When I rotate my engine, the marks on my main pully line up directly with the dizzy......I mean it's dead center on the marks.....
The Fox
Carrera
Old 07-03-2004, 10:25 PM
The dizzy mark is just a start guide to get things lined up. The important next step is to line up the marks on pulley and fan housing. Do it on a nice day with some cold corona beer!
Old 06-03-2016, 12:22 PM
83 911 Production Cab #10
JJ 911SC's Avatar
I'm sure he figure it out by now, 12 years later
Who Will Live... Will See
Old 06-03-2016, 12:25 PM
bcheney's Avatar
TDC Z1 mark on 3.2
Ok guys does this look correct for the TDC Z1 mark on a 3.2? Doing my first valve adjust on this engine and want to be sure.
08 Cayenne V6
89 911 Targa Carrera 3.2
75 914-6 Conversion
Old 12-29-2016, 06:24 AM
bcheney's Avatar
TDC Z1 on 3.2
Ok this photo shows both marks on the pulley
08 Cayenne V6
75 914-6 Conversion
Old 12-29-2016, 06:42 AM
Yes, you are positioned at TDC. Just double-check that the intake and exhaust rockers are able to move.
David Yerkes
1987 911 Targa - GP White
Old 12-29-2016, 07:05 AM
bcheney's Avatar
TDC Z1 mark on 3.2
The exhaust valve rocker can move and I can get the blade in between the rocker and valve. The intake rocker moves but I cannot get the blade in between the rocker and valve. Not sure if the clearance is just too tight and I need to loosen or if I am maybe not on the TDC Z1 mark and should bump the pulley slightly?
08 Cayenne V6
75 914-6 Conversion
Old 12-29-2016, 07:36 AM
