redranger's Avatar
Turning pulley and crankshaft
86 911. Trying to adjust valves. When I turn the fan nut clockwise, the crankshaft pulley below doesn't turn so I can't line up the marks properly. I guess the belt is too loose and won't grip?? Tried pushing on the left side of the belt to snug it up a little, but no luck. Any trick to getting it to turn? First time adjustment for me...be gentle.
Old 08-23-2009, 06:25 PM
Friend of Warren
Push in the middle of the belt. If that doesn't work take out the spark plugs.
Kurt V
Old 08-23-2009, 06:47 PM
I've had luck putting pressure on the left hand side of the belt and at the same time moving the ratchet/breaker bar in a bit of quick "jerky" motions. you may beat the top of a compression stroke making it harder to turn. Good luck!
Rutager
Old 08-23-2009, 06:58 PM
E Sully's Avatar
Seem like a good time to adjust the belt or replace it. You can try moving one of the shims to the outside to tighten the belt.
Old 08-23-2009, 07:13 PM
pete3799's Avatar
Push in on the right side of the belt while turning.
Pete
79 911SC RoW
Old 08-23-2009, 07:41 PM
80-911SC's Avatar
search my name and check my post with same problem ,
Old 08-23-2009, 10:09 PM
redranger's Avatar
Thank you!! That was the trick, turns fine now. I'll probably change the belt pretty soon, not sure when it was last done, seems like a pretty simple job...with my luck, the shims will crumble.
Old 08-24-2009, 04:42 PM
T77911S's Avatar
this is correct. the right side. turn slower as compression builds.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 08-25-2009, 05:02 AM
