-   -   Easy hood alignment (http://forums.pelicanparts.com/porsche-911-technical-forum/170723-easy-hood-alignment.html)
Steve87-911 07-03-2004 03:14 PM
Easy hood alignment
So I'm thumbing thru the Bentley book last night and stumble upon the front hood adjustment page (550-2). The front left of my hood had been slightly higher then the left. About 2 minutes after reading that page, the hood was nicely aligned. Just a couple twists of the rubber stops (duh)...no tools...all done.
Sometimes life is so busy that I miss the easy details like this one.
svandamme 07-03-2004 03:35 PM
i got a different issue with mine
the allignement is correct, but the new rubber seal seams to be to thick
so it pushes the hood upwards
is that normal ? should i cut up the rubber ?
it is nicely settled in the chassis, can't push it any deeper
the lower side fits perfect, it's just the upper side of the fold that seems to rigid
Paulporsche 07-03-2004 04:35 PM
I don't see how cutting the rubber could hurt.
Paul
