-   -   finally found time to install turbo tie rods and ERP drop links (http://forums.pelicanparts.com/porsche-911-technical-forum/170822-finally-found-time-install-turbo-tie-rods-erp-drop-links.html)
dickster 07-04-2004 11:42 AM
started by jacking front of car and removing both wheels.
heres the old ones
http://forums.pelicanparts.com/uploa...1088966203.jpg
heres why i need drop links - out end of rod much higher than rack end.
http://forums.pelicanparts.com/uploa...1088966251.jpg http://forums.pelicanparts.com/uploa...1088966268.jpg
remove rod ends first - left side fell out with hammer applied
http://forums.pelicanparts.com/uploa...1088966354.jpg
other side wasn't so easy.
http://forums.pelicanparts.com/uploa...1088966407.jpg
hammer and special removal tool wouldn't work so got the drill out!
http://forums.pelicanparts.com/uploa...1088966474.jpg
i ground down the threads and then drilled the centre out with 8mm drill - fell out with a tap of the hammer.
more to follow after the football.......
dickster 07-04-2004 01:48 PM
remove tin protecting rack and fuel pump
http://forums.pelicanparts.com/uploa...1088973871.jpg
http://forums.pelicanparts.com/uploa...1088973899.jpg
remove springs retaing rubber boots so that boots can be pulled to one side.
remove rods. left side just need turning to 90 degrees, right required blunt chisel to retaining nut.
http://forums.pelicanparts.com/uploa...1088974028.jpg
rods removed from car.
old v new rods
http://forums.pelicanparts.com/uploa...1088974076.jpghttp://forums.pelicanparts.com/uploa...1088974131.jpg
dickster 07-04-2004 01:52 PM
assemble new rods same length as old. i replaced turbo rod ends with spherical bearing type supplied with drop link kit.
assembled apply thread lock
http://forums.pelicanparts.com/uploa...1088974268.jpg
screw on new rods to rack (replace rubber boots before this if using turbo rod ends, and i also did not need the large washers/spacers supplied)
http://forums.pelicanparts.com/uploa...1088974356.jpg
dickster 07-04-2004 01:55 PM
refit rubber boots - i lubed the ends with engine oil to ease fitting.
http://forums.pelicanparts.com/uploa...1088974477.jpg
i also used zip ties - i gave up with the spring retainers!
http://forums.pelicanparts.com/uploa...1088974518.jpg
dickster 07-04-2004 01:59 PM
assembled droplinks.
http://forums.pelicanparts.com/uploa...1088974580.jpg http://forums.pelicanparts.com/uploa...1088974599.jpg
finished left and right sides
http://forums.pelicanparts.com/uploa...1088974649.jpg http://forums.pelicanparts.com/uploa...1088974672.jpg
refit rack protection/wheels etc. it can be a PITA to get the rear bolts in the rack cover tin (sway bar support) and i found it much easier if i tightened up the front nuts first - this pulled the rear into line.
only a small gap now
http://forums.pelicanparts.com/uploa...1088974740.jpg
dickster 07-04-2004 02:01 PM
drives great.
http://forums.pelicanparts.com/uploa...1088974824.jpg http://forums.pelicanparts.com/uploa...1088974841.jpg http://forums.pelicanparts.com/uploa...1088974857.jpg
now i need an alignment.
Schrup 07-04-2004 02:25 PM
Rich, car looks great!!! How low is it now? Do you plan to go lower? I am posting this link for anyone (like myself) that wonders why you would leave off the spacers.
http://forums.pelicanparts.com/showthread.php?s=&threadid=155818&highlight=Turbo+ tie+rod+washers
Steve W 07-04-2004 02:55 PM
Rich, not sure how you got by without using the rack spacers, as they're not really spacers but rack stops. Some guys on this board also did without the spacers and ruined the steering rack in no time.
http://forums.pelicanparts.com/porsche-911-technical-forum/84284-steering-rack-failure.html
Zeke 07-04-2004 04:03 PM
I too, thought there was an necessity for the spacers. I know they look like the shorten the amount of usable thread, but I put them on just the same.
I see a Stanley dual scale tape measure. Do the Brits look at the inch scale much? :D
Silveresrty911S 07-04-2004 07:07 PM
Rich, it also looks like the front torsion bar adjuster is backed WAY OFF! Unless you just did that, I've been under mine all weekend installing new 22/28 t-bars so everything looked familiar except the 11mm bolt for adjusting the height.
Thanks for the write up as I'm doing the turbo's next week.
Schrup 07-04-2004 07:15 PM
Rick, what kind of shocks do you have & are they new?
Lukesportsman 07-04-2004 07:37 PM
Thanks for the write up for those of us getting ready for this improvement. Got to love you Brit's garages. I lust after them in the back of CSC Magazine every month. Just love the carriage house look and quality wood construction over our "manufactored" looking garages.
Did you light a firecracker for us tonight :)
dickster 07-04-2004 11:35 PM
thanks! its at about 23.75/24.25 r/f - no i would prefer it slightly higher - 24/24.5 - thats what i'll aim for with an alignment when everything is done. the A arms are pointing the wrong at the moment.
the spacers are left out with the ERP drop links, the instructions say so! and i confirmed with smart racing (as i said in the thread you refer to).
steve, yeah i know, and without the ERP kit i would have used them.
the ERP kit has been improved with longer rod ends which necesitates (sp?) discarding the spacers.
funny! actually i still prefer inches - can't get my head round the metric system.:D
i adjusted the height when i did the t/bars. i hope you find it helpful - it was pretty easy, the only PITA was a rod end i had trouble with, but now i wouldn't waste time, i would just drill it out.
i have the bilstein sports, and they're pretty new. they need revalving for the t/bars though.
thanks. its my parents place - but i got my eye on it.......
;) but i have to confess (on the old mans behalf) that it is block construction with timber cladding (planning requirement as its in farm land area) - still it looks nice!
sorry, i got side tracked by the football - but i did think of it - happy (belated) 4th july;)
dickster 07-04-2004 11:39 PM
the car feels much nicer, the steering more direct. the drop links have made the car alot less "darty". i think i may have found a cure for the strange - one sided - understeer problem i was chasing. it may have been the old rubber jointed steering arms, because first impressions are that left right turns are now the same.
definitely recommend the turbo kit for anyone, and the drop link for all your lowered cars.
AirCooledExcellence 07-05-2004 08:20 AM
Good job Rich!
There's definitely 'night & day' difference between the old rubber ones & turbo rods, those drop links look cool too!
Cheers,
Tim.
Glasgow 911SC 07-05-2004 11:30 AM
Are these the 9meister drop links Rich?
How's the wee man by the way? He's keeping you busy I guess.
jester911 07-05-2004 11:49 AM
Looking good Rich. Thanks for the replies on my post on generally the stuff I am talking about on my car.
Bet it feels great:D
dickster 07-05-2004 12:54 PM
hey jerry, yeah it feels great to get it done at last! i've had this stuff lying around for ages.
good luck with yours.
chris,
no, these are the smart racing ones.
he's doin great - teething:rolleyes: - thanks for asking (and remembering:) ).
tim,
yeah, they do feel good - hopefully i've cured the handling probs now.
