I would rather be driving
jpnovak's Avatar
Help! creaping ignition advance, weak springs?
Now that the project is up and running I am trying to get it all tuned up. I am really having a hard time setting timing.
78 SC 3.0 with webers.
I am trying to set at 30deg max advance at 6K. I have no tach and thats another post. So back calculating from the max advacne of the dist I get about 10-12 deg BTDC at idle.
Here is my problem. If I set the timing anywhere bast 0 deg TDC the advance slowly creeps up to max advance. of course, my idle speed goes right along with it.
I have disassembled the dist. two times and I KNOW the weights are not sticking. I was wondering if stronger springs are needed. Do these dist springs wear out and lose their K?
Is there anything else to check if its sticking? I can't find anything.
Old 07-03-2004, 02:10 PM
jpnovak's Avatar
How about them fireworks!?
Old 07-04-2004, 03:25 PM
I don't understand your problem. At idle the advance changes or when you rev it? I do think springs can weaken with time and heat.
Dean
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 07-04-2004, 04:23 PM
jpnovak's Avatar
At idle the timing changes due to the advance. The dist is tight and I get about 20deg advace, equal to the total advance of the dist.
this means I can not set timing because it is dynamic when it should be static
Old 07-05-2004, 09:48 AM
Does the centif. adv. feel weak? Turn the rotor by hand and see if it is very weak. You can get springs a your local speed shop and try stiffer ones
Dean
Old 07-05-2004, 11:22 AM
jpnovak's Avatar
the rotor turns and snaps back without any problem. compared to my targa I don't feel much difference in tension.
I see if I can locate stiffer springs
Old 07-06-2004, 07:07 AM
