-   -   I Really Messed Up - Please Help (http://forums.pelicanparts.com/porsche-911-technical-forum/170978-i-really-messed-up-please-help.html)
scottb 07-11-2004 10:12 PM
Do a search for "idle hunting." You'll get some answers. I had a similar problem. I replaced the O2 sensor, the head temp sensor and the idle control valve, but nothing helped. Then someone suggested mixture. I had my mechanic tweek the mixture...problem solved. Sometimes the simplest solutions are the best.
Scott
cwinters01 07-12-2004 08:38 AM
Thanks Scott. I did find a ton of info on this on the website. Great stuff! It started right up this morning and is idling well so far, after setting the mixture last night.
Thanks again,
Christian
ruf-porsche 07-12-2004 02:23 PM
Originally posted by cwinters01
But hey, I have a propane torch for when I need one now, and I'm sure that I'll need one sooner or later from all of the reading that I have done here. Adding to my tool collection as we speak.
Thank you again everyone!
-Christian
I use my propane tourch to light the charcoal for the Bar B Que.
