47silver's Avatar
horn pad removal
hi:
i read the post on horn pad removal,,i have a 1975 with teh rectangular horn pad...how does it come off? It looks like the plastic may clip into the metal ring and can be removed but the other posts indicate that you remove the whole arrangement by pulling on it... how is it done?
thanks
gary
1975 911S Targa
Silver Anniversary Edition
Old 07-05-2004, 10:11 AM
Doug Steinel's Avatar
I use a screw drive and gently pry if off. I would disconnect hte battery first, and be aware that when the pad pops off it will still be connected to the wire.
77 911, 3.0L
Old 07-05-2004, 06:46 PM
47silver's Avatar
horn pad
Doug:
Thanks for the information,,, do you put the screw driver under the metal part or the plastic?
gary
1975 911S Targa
Old 07-06-2004, 05:18 AM
