WYDBODY1986's Avatar
Front tire choices
Hello all, new subscriber here.
I need to replace the front tires on my 86 911 TL because they are flat spotted so bad from sitting that the they cause a wicked vibration in the steering wheel. My question is about tire size. Which would you choose for the front end of the car, the stock 205-55-16 or what the PO put on it 225-50-16? Would the smaller tire have a noticible effect on reducing steering effort? The car is used as a toy on the weekends for drives up the beach and an occasional autocross and hopefully in the future a DE event or two. Thanks for the opinions, this such a cool site for info on any Porsche subject you could imagine
Old 07-06-2004, 08:20 AM
I'd go with the 205 55's. They should reduce the steering effort, and they will have reduced sidewall flex.
Old 07-06-2004, 08:47 AM
Bill Verburg's Avatar
If you aren't having any fender interference issues and the ride height is where you want it I would stay w/ the 225/50
Be aware that a nominal 225/50 from one manufactuere will not measure out exactly the same as from a different manufacturer
Bill Verburg
Old 07-06-2004, 08:51 AM
Certified Pre-Owned
BGCarrera32's Avatar
Just my 2 cents...
What I would do, especially since its sat that long to cause that kind of a problem, is replace all 4 with the stock sizes and get fresh rubber. Get to know your car and do a DE or two if so inclined before you get talked into different wheel and tire combos. Be advised that running different makes of tires front and back can cause you to fail tech inspection before a DE in some regions (has to do with different tires compounds, how they heat up, etc.).
'84 Carrera Coupe
Old 07-06-2004, 09:00 AM
bigrubberjeep's Avatar
Try 215-50-16 for the front
85 911 SuperSport
No more looking! The jewel is mine!
89 Jeep Wrangler
A jewel in the rough
2000 Grand Cherokee
Family Wagon with Jewels on board
Old 07-06-2004, 09:12 AM
rdane's Avatar
If you have the option the 225/45/16s work very well as the others mentioned. I am using the 225/45-245/45 SO3s on mine and like them a lot.
Old 07-06-2004, 09:21 AM
IROC's Avatar
You got plenty of room (given the turbo bodywork). I'd go for the 225s for sure.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 07-06-2004, 09:59 AM
Automotive Monomaniac
Emission's Avatar
Before you replace the tires, make sure thier pressure is up and take them for a good 30 minute drive. My tires get "flat spotted" when the car sits for more than a week or two... and the wheel shakes for the first mile or so as a result. 99.9% of the time, it isn't permanent and it will go away once the tire is warmed.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 07-06-2004, 10:49 AM
MY83SC's Avatar
My car, basically having been a daily driver, I have never had a problem with a flat spot. I did expeiriance it when I had 2 new tires mounted in the rear. After a mile or so, the sound stopped. Had me a "tad" worried at first. Problemo has not returned since.
Mike
83 SC
Old 07-06-2004, 11:02 AM
