-   -   915 Fill Procedure (http://forums.pelicanparts.com/porsche-911-technical-forum/171134-915-fill-procedure.html)
Porsche_monkey 07-06-2004 01:35 PM
915 Fill Procedure
Dopey questions:
I assume I should just pull the side plug and top up until it overflows out the side?
How do most of you get the oil in the top? Pump it?
William Miller 07-06-2004 02:17 PM
I did mine at a local tech inspection. The shop provided a pump that looked kind of like the tube of a grease gun with a hose sticking out of the top. He stuck the tube in the oil container and pulled the handle sucking some up then stuck the tube in the top/side hole of the tranny.
Pushed it in.
I have an oil pump I use for the outdrive on my boat. This works like a bigger version of the pump on a windex bottle. These pumps screw into the top of the plastic quart oil container. It's cheap like $10 at the discount marine store and I think easier to control.
I was lucky I didn't need the big allen wrench for the plug.
I'd check yours before buying one.
Good luck!
svandamme 07-06-2004 02:23 PM
while in the car, you could pump it in using a plastic bottle
some do it by setting the oil canister on a ladder, and use a hose to the filler , then suck and gravity does the rest
there's some pics on a thread from couple of months ago
http://forums.pelicanparts.com/showthread.php?s=&threadid=157126&highlight=swepco +AND+ladder
Randy Webb 07-06-2004 03:11 PM
Be sure to undo the fill plug before taking out the drain plug! Some have found they could not unscrew the fill and sat around for weeks with a dry trans while they beat at the plug with various weapons....
84toy 07-06-2004 06:28 PM
I have a plastic hand pump that screws in the top of a one gallon jug and has a hose attached, you can buy them at Wally-Mart. I pour in the proper amount of fluid and with the car on jack stands, I pump until the jug is empty. I just changed my tranny fluid and it took about 15 minutes total.
jmohn 07-06-2004 08:07 PM
I use the gravity method, but rather than re-write several paragraphs, try the search button. There have been several threads on this and some good info in most of them.
Jerry M
'78 SC
john70t 07-06-2004 11:21 PM
If the proper fill-plug tool isn't immediately available, you can get away by grinding the hex-head of a bolt to fit, and good vise grips close to it to turn.
aigel 07-07-2004 01:12 AM
I have a fluid dispenser for these things that looks like an oversized syringe. About $20 at your favorite tool place. I like thetoolwarehouse.net, it has better quality than harbor freight.
HTH, George
