-   -   Identify this wire for an SC (http://forums.pelicanparts.com/porsche-911-technical-forum/171167-identify-wire-sc.html)
mtelliott 07-06-2004 05:20 PM
Can you identify this wire from the wiring harness on an SC. The wiring harness is an 81 SC, engine is an 82.
http://forums.pelicanparts.com/uploa...1089159516.jpg
http://forums.pelicanparts.com/uploa...1089159568.jpg
I can't figure out where it goes. It's position suggests it goes around the 1 - 3 cylinders. Maybe it's extra for the air pump (which I don't have on my year)?
Any thoughts?
Michael
scoll911 07-06-2004 05:27 PM
I have a similar wire on my 78 -- mine connects to part of the vacuum system (attached to the CIS at the #3 cylinder).
smestas 07-06-2004 05:54 PM
I have the same wire also on a '78 that connects to the "Thermo Valve" part of the CIS system.
I tried to look it up in the Pelican catalog for you but there is no listing of a "Thermo Valve" for a 1982 model?
Here is a image of the part that the wire connects to on a 1978. The plug connects to the back of the valve and its not shown in the image below.
http://www.pelicanparts.com/catalog/..._1-7-2d17a.jpg
Doug E 07-06-2004 06:25 PM
My '81 doesn't have anything that looks like what you are holding in your hand in picture #1.
The gray connector in picture #2 is what's hooked to my oxygen sensor after it is threaded through the engine tin.
mtelliott 07-06-2004 07:05 PM
Both pictures represent the same item. I'll look around the number 3 to see if there is a connection. The wires are brown and red/white if that helps anyone.
There is another similiar wire that goes up around the plug near the oxygen sensor connector but this one is different.
Michael
sammyg2 07-06-2004 07:26 PM
Looks like the heater wire connections on the O2 sensor to me.
emcon5 07-06-2004 07:32 PM
No heated O2 on SCs. Mine has the same thing, connected to nothing. As I understand it, it goes to a vac cannister that is not on late model SCs.
Tom
1980 911 sc 07-06-2004 08:37 PM
is it the wire that goes to the WUR?
William Miller 07-06-2004 08:45 PM
On my 83 Euro it goes to the thermovalve. My CIS setup is like the 79.
Maybe it's just not used on the US model. Th wire bassically provides + and - while the engine is running to heat the element inside the thermovalve and open it. Much like the bimetalic strips in the AAR and the WUR.
The thermovalve is not a Bosch part as far as I know.
wswilburn 07-06-2004 08:56 PM
My 82 SC has a similar connector that goes to nothing also. Cabled tied into a bundle with black tape over the connector.
oneblueyedog 07-06-2004 09:14 PM
It's the vacuum switch wire to the red item in the diagram posted. Do you have plastic fuel lines?
sammyg2 07-06-2004 09:15 PM
Mine had it, I didn't know what it was for, I even posted the question. then I found that it fit perfectly on the connection for my heated O2 sensor (from a later model year) so i assumed that it was it is for.
Oh well, even if it wasn't intended for that use it works perfectly.
aigel 07-06-2004 11:13 PM
I have a blank pair of wires with no connector in the same location. I figured it was going to the alternator (before it was converted to internally regulated). But that's just a wild guess. I figured if it runs great without, why worry!?
Does yours run good? When did you find this?
George
smestas 07-07-2004 01:38 AM
I looked up the thermo valve part number using PET and it has the part #911 606 106 01 for a '82 motor. When you look this up in the Pelican catalog it shows up '77 to '79 but PET says different?
I just finished my rebuild and the only conector like that went to my Thermo Valve.
mtelliott 07-07-2004 06:52 AM
Background: I'm rebuilding my engine with a new wiring harness. I found an '81 harness that I figured would be close enough for an '82. I bought it off a Pelican member who actually got it as part of a liquidation of a Porsche shop.
Anyway, I looked at the wiring diagram in Bentley's and it appears that it goes to something called the auxiliary air valve. Now, I have no idea what the auxiliary air valve might be and could find no further reference. Maybe that is what Simon is referring to as a Thermo Valve.
Now, what is the heated O2 sensor? Where is that located? Is that something on later cars?
Michael
oneblueyedog 07-07-2004 07:03 AM
Since you have a hybrid setup. Compare the wiring diagrams from different years. When I recovered my harness in heat shrink, I eradicated the wire that was hanging free that goes from the alternator to the extternal regulator. Why? Since the VR is now combined in the alternator, I hated taped wires and a connector hanging free.
If the connector serves no purpose for your year model and there are no ramifications to leave it free, dont sweat it.
Lee78SC
enolam 07-07-2004 01:04 PM
the aux air valve looks like the red thing in the picture above. It's located over the #6 cylinder and causes faster idle when the engine is cold but I don't believe it will accept that kind of connector. The SC I had had the same wires that didn't connect either.
mtelliott 07-07-2004 01:31 PM
I'm going to take a look at it tonight and if I can't find a link there, then I'm going to say it's extra and not worry about it.
Thank you all for your advice.
