Jcon's Avatar
Charcoal Cannister ????
Does this thing ever need replacement? I'm getting pretty strong gas fumes outside the car, but I can't find a leak. I know that the tank vents thru the cannister..could the cannister be the issue. Do these things go bad?
Jeff C
Jeff C
76 912E 2.6L
Old 07-09-2004, 03:28 PM
Jcon's Avatar
Bump for the west coast crowd
Jeff C
76 912E 2.6L
Old 07-09-2004, 06:49 PM
The charcoal generally doesn't wear out; I suspect you have a disconnected or broken vent hose/line or vapor collection cannister somewhere. Start by looking up front. Jim
Old 07-09-2004, 09:00 PM
Would have to second that. The lines running from front to back get pretty old and cracked.
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 07-12-2004, 09:19 AM
I also have a fume problem with my 3.2 conversion. The PO put the charcoal canister and vent in the smugglers box. This put the fumes into the ventilation system. My car is smog exemt, so I lost the canister, and put the vent line up into the filler area. This put the fumes right outside the drivers window. They get worse at stoplights on hot days.
Did you do your own 3.6 swap? Do you have all the appropriate tank, cap, cannister, and lines for a 3.6?
I think I'm going to have to try and duplicate the stock system, unless someone has an easy solution.
'69 911 Targa w/ 3.2
Old 07-12-2004, 10:35 AM
Randy Webb's Avatar
either put the canister back in (which will completely solve the problem) or vent to the wheel well
Old 07-12-2004, 10:41 AM
For the sake of the environment (even if only a small sake), put it back in and run the lines properly.
Michael
1997 BMW M3 (Hail)
1985 928 S (Sold)
Old 07-12-2004, 11:55 AM
