I have a 1985 Targa and, when driving, the car seems to surge. I'm starting to feel like I'm in a rocking chair and hoping that it's just something simple like a relay. (and it's not my foot on the gas) It doesn't seem to happen at any given temp, rmp, or speed - but you can pretty much feel it all the time unless you're on the gas. Any advice? Also, could someone tell me if there is a valve cover torque spec, and what it might be? Thanks!!
Kim pic attached - it's in great shape otherwise....
Valve cover torque ain't causing this problem. Could be a fuel delivery issue, intemittent miss, DME. Need more details.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
More specifics on surging....please:
Torque for Valve covers is 6 ft/lbs.
The Fox Carrera |
Perhaps I'll just buy a new gasket anyways. |
Don't mean to highjack the thread here, but what is the cause for intermitent back fire "pop" sounds?
85 911 SuperSport No more looking! The jewel is mine! 89 Jeep Wrangler A jewel in the rough 2000 Grand Cherokee Family Wagon with Jewels on board |
Check the WOT switch and it's connections first. Then, cap and rotor, plugs, IC switch, hoses and lines to the throttle housing for secure fitting. This before getting into parts replacement.
How long have you had the car?
The Fox Carrera |
Sorry....referring to Kim
The Fox Carrera |
I've had the car for one week as of today!
You've had the car for 1 week......
Oh Boy...... Once you get past the ribbing, get to know the folks on this board immediately......
The Fox Carrera |
isn't dme relay a "first choice" swap for almost any problem on a 3.2?
It's two relays in one housing that control power to the fuel pump and engine managment computer. If you look under your driver's seat, you'll see a small black rectangular box held in place by a single bolt. That's the DME relay. Over time, some of the solder joints on the circuit board inside can develop stress cracks that cause intermittent operation, and eventually a non-running condition.
David Dryden '86 911 Coupe '05 BMW X5 4.4i |
Our 1988 does the same thing, but it is very subtle. When accerating (using part throttle) below approx 4000 rpm's the car pulses, or hesitates. It is very subtle, but there for sure. When going to full throttle above 4K it seems to be OK. However, I dont know how hard the car should pull, the power seems fine. Is this normal?
Any input? David
2007 911 Turbo 6-speed, 1984 911 Carrera, 1974 911S, 75 914-6 conversion/project, 2007 Mercedes SL63 AMG, Coyote Powered FFR Cobra |
Ok, so the DME relay looks to be about the same size and seems to have the same function as the fuel pump relay in my VW - except for that one's only one piece and it's not under the seat.
It doesn't look too hard to get at, but would probably be easier if I removed the seat. I didn't look to hard at it last night, to see the best way to get at it - any advice?
You don't need to remove the seat. Just pull the plug and slap in a new one. If that fixes your problem, then unbolt the old one and bolt the new one down in its place. Then buy another new one and keep it in the glove box.
Make sure to "true" up the Valve covers on a large (machine shop") belt sander, they tend to warp. use new gaskets ,sealing rings, and nylox......Pelican carries this stuff. Torque on those are low i believe only 9 foot pounds
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug 1984 Mercedes 500 SEC 1991 Mercedes 420 SEL 1992 Ford F-350 Dually 28' Pace Trailer |
Automotive Monomaniac
My '86 does the same thing (a slight pulsing while driving).
I assume turbo's also have the identical DME relays as well? Are there two identical relays on each car?
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) Last edited by Emission; 07-07-2004 at 08:51 AM.. |
Could a relay cause a light surge or hesitation? I could see it causing a car to to stall or cut out, but I dont see how it would affect part throttle. I am confused on why it wouldnt affect full thottle above 4K rpms. New to the Porsche stuff, so could be missing something.
