MarkY's Avatar
Send a message via Yahoo to MarkY
Lifting a Carerra with a jack plate
I have a 1988 Carerra that I'm getting ready to pull all the wheels off to get some new tires mounted. I'm going to put new brake pads on while I'm at it.
Does anyone know if you can lift one side of the car high enough to put jack stands under it when using a jack plate? The reason I'd like to use the jack plate is because my car will need to stay on the jack stands for a couple of days and my garage isn't deep enough to put the car in and also be able to manipulate a floor jack behind it.
Thanks for any info.
Mark
1988 Black on Black coupe
Old 07-09-2004, 09:56 PM
Send a message via AIM to fintstone
Depends on the jack. A "high lift" jack will certainly do the job.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 07-09-2004, 10:12 PM
MarkY's Avatar
The jack will lift high enough. I'm wondering about any undue stress on either the jack plate or from "tipping" the car that much.
Mark
Old 07-09-2004, 10:28 PM
Now in 993 land ...
aigel's Avatar
Should be no problem. If you have the small jack stands it doesn't need much height. If you have big jack stands, you will need a big jack. It all scales ...
What I am saying is: If you have a small jack, don't use the big jack stands, otherwise all other combinations will work.
George
81 SC (sold)
Old 07-09-2004, 10:32 PM
Yes, the only real constraint is the jack...unless of course you had severely corroded jacking points...then all bets are off...which an '88 in AZ certainly should not have.
Old 07-09-2004, 10:38 PM
fred cook's Avatar
Cool Jacked up.....
No sweat, I do it all the time on my '80 SC coupe. Simply lift one side, place the jack stands and then go to the other side. Piece of cake! The jack that I use is a 2 1/2 ton floor jack that I bought at an autoparts store several years ago. The lift range on it is from about 4-5" up to about 20". The best thing about using a lift plate is that it leaves the best spots for the jack stands free and clear.
Good Luck!
Fred Cook
'80 911SC coupe
Old 07-10-2004, 05:20 AM
