Engine Shroud for 77 911 3.0 ROW
Just wondering what other 911 engine shrouds I can replace mine with? Mine is not in bad shape but I think would be a good idea to change in the next year or two.
If I pull the motor, how difficult would it be to switch? Any special tools required? Do I need to replace any gaskets? Please no while you were in there? I don't need any other ideas to ponder.
Thanks,
Old 07-08-2004, 11:13 AM
Re: Engine Shroud for 77 911 3.0 ROW
Originally posted by Argeo
Mine is not in bad shape .
some guys have successfully painted them.
simple brainless switch.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-08-2004, 11:22 AM
Hi Ronin,
Maybe I am describing the wrong thing. The plastic piece that the fan shroud goes into. Whatever that is called. Mine looks fine but where the fan shroud connects this plastic thing, some of the holes in the plastic have broken through basically reducing the number of bolts holding the fan shroud on. Mine is orange/red plastic. I don't care if the color is different, just wondering if others will fit.
Sorry for the confusion,
Old 07-08-2004, 11:34 AM
Hi Ronin,
Oh.. the "air guide" that houses the alternator ?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-08-2004, 11:49 AM
That's it. I apologize. I am thinking it can't be an easy replacement but with winter being so long, it should be doable.
Thanks again,
Old 07-08-2004, 11:52 AM
personally it's a delicate connector area. a little to much screw torque and it gets damaged. I'd custom build a real metal ring and epoxy the unit together.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-08-2004, 12:05 PM
Good idea if I am thinking what you are thinking. Make a metal ring that somehow I connect to the Air guide and have the connecting bolts run through that and into the the shroud. How do I connect plastic to metal strip?
Old 07-08-2004, 12:24 PM
Designer King
Paulporsche's Avatar
You can put the ring over the plastic, with the holes aligned, and use it as a clamp.
Paul
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 07-08-2004, 12:33 PM
Good idea if I am thinking what you are thinking. . How do I connect plastic to metal strip?
probably anything flexable like silicone gasket material. All you want is for the ring to stay attached to the air guide while your putting in the screws.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-08-2004, 12:45 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
Epoxy would work pretty well. You just need to prep the surface, make sure you sand the metal raw and clean up the plastic as much as you can and you can get a great bond.
74 911s neverending story. two feet and a jetta for now.
Old 07-08-2004, 12:50 PM
yep.. that was my first thought.. but it's expensive to start with new epoxy materials.. the silicone is cheap.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-08-2004, 12:54 PM
