-   -   Problem at the track today-VERY expensive valve stem! (http://forums.pelicanparts.com/porsche-911-technical-forum/171501-problem-track-today-very-expensive-valve-stem.html)
A Quiet Boom 07-09-2004 04:39 PM
Originally posted by Bill Verburg
As Jim said
You need to use the short metal stems w/ metal caps w/ an inner seal, like this
At speed the unsealed caps have been known to leak
Totally agree with this point, learned the hard way running drag slicks at 130! At least I didn't wreck, but it was close. Sealed caps are a must and steel stems are well worth the investment. Also check your pressures regularily, even if it just saves tire wear it's worth it. ;)
