twobone's Avatar
What sounds like a cat being dropped in a wood chipper...sorry cat owners
When I turn on the fan in my 81' SC I get a screaming sound. It sounds like....OOOOOOOEEEEEEEEEEEEEEEEEEEE
Is that an easy fix or a big dash-puller type fix.
Mike
Old 07-06-2004, 08:53 PM
geof33's Avatar
Easy, new belts... properly adjusted...
GruppeB #935
84 Carrera Targa B.A.S.T.A.R.D. (for sale)
82 SC RSR Project (on ebay)
95 Dodge Ram 2500
03 Toyota 4runner
Old 07-06-2004, 09:00 PM
geof33's Avatar
Oops wrong fan....
This is the bearing in the main blower. You might be able to lube it, but just try running it for awhile, it whould subside. Mine used to do that just at startup then quieted down. Now it doesn't do it unless it REALLY cold... then only when first turned on. How long since you had the blower running?
GruppeB #935
95 Dodge Ram 2500
03 Toyota 4runner
Old 07-06-2004, 09:02 PM
Cat in a woodchipper would sound more like:
"Meow-WUFFP-tscht-tscht-tscht-tscht"
Audi B7 S4
geof33's Avatar
Very funny!!!
GruppeB #935
95 Dodge Ram 2500
03 Toyota 4runner
Old 07-06-2004, 09:14 PM
Sonic dB's Avatar
My cat would eat that woodchipper for breakfast...and still have room for a chainsaw for lunch.
KobaltBlau's Avatar
Don't let 'im get behind the brake pedal!!
Andy
Old 07-06-2004, 09:45 PM
Silveresrty911S's Avatar
Open the front hood and remove the (card board?) cover and you'll see the blower assembly, remove some ducts and lube the blower. Gives you a chance to clean out the area, mine had alot of leaves and debris. Mine hasn't squeeled since.
Rick
'76 Carrera 3.0, track
'77 3.2 targa, back home
'95 993 C4 M030, SOLD
PCA San Diego
Old 07-07-2004, 04:17 AM
jgporsche's Avatar
I lubed mine (73 911) and a few days later the whine came back. If it's shot, may have to replace the motor.
Silverresety911S what did you use to lube yours?
1994 968 "Totaled during practice for GBRS / PCA 2009 Race season"
1989 944 Track car replacement. Complete with 968 running gear.
1988 911 Carrera "Friday / Weekend Driver"
1988 944 Daily Driver now.
1973 911S "In storage"
Old 07-07-2004, 06:58 AM
Soon as I can catch my cat, I'll complete my research and get back to you.
Old 07-09-2004, 09:09 AM
You'll probably just need to replace the motor. lubing it is probably just a temp fix.
Old 07-09-2004, 09:39 AM
Jamie79SC's Avatar
Silveresrty911S, now you have ducks up there too?
Jamie79SC
Old 07-09-2004, 11:06 AM
twobone's Avatar
Thanks - seems almost fixed
The fan will hold settings 1 and 2 OK. If I put it on 3, it will run for 2 seconds and then die. I guess I'll stick to fan speeds one and two
Old 07-09-2004, 12:13 PM
Designer King
Paulporsche's Avatar
A few years ago I replaced my motor, after having lubed it for some time. I went to a Bosch distributor and paid a lot less for just the motor, as opposed to paying a whopping sum for the whole assembly from the dealer.
Paul
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 07-09-2004, 12:20 PM
Formerly bb80sc
Vipergrün's Avatar
I love cats.......they taste just like chicken.
Bite me PETA!
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 07-09-2004, 01:00 PM
