Tut Tut is offline
Optima mounting plate question
I've read the threads regarding the fabrication of a mounting plate for an Optima out of a synthetic cutting board. My question concerns what people have done at the end of the mount toward the back of the car, where the battery/mounting plate slips under the lip that is there. I don't believe that the Optima has a lip at the end of the battery, although I may be wrong. Have people doubled the thickness of the mount at that area so that the mount is wedged under the lip?
Thanks.
Tut
'87 Carrera coupe
'08 BMW 535 xiT
Old 03-26-2008, 04:38 AM
Banned
I just put in an Optima.
I used a universal battery tray and hold down clamps from Pep Boys.
I had to do a little fabrication on it where it slids under the lip in the rear as well as in the front where the original hold down clip fits. I think just some notching.
It was easy.
Old 03-26-2008, 06:49 AM
A thicker cutting board would be better. I have the same problem, the cutting board does not fit as tight as I would like in the rear cleat as shown. Has anyone come up with a good soultion?
John Adams
1980 ROW 911SC
Old 03-26-2008, 06:52 AM
Mitch Leland's Avatar
Battery Mount...
Tur,
If I have you question right, the cutting base board fits under the lip, the battery is bolted to the base board. If you wanted a tighter fit under the lip with your base board I assume you could thicken that end by attaching a strip of the same material to the base board. However when I did mine the base board is pushed into the lip so it really can't go anywhere anyway...
Here's a pix of the forward end, I used a S.S. bolt and I also ran the router over the top edge, maybe that will make my car go faster...
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 03-26-2008, 06:54 AM
gtc gtc is offline
abides.
gtc's Avatar
How thick is your cutting board? I had to try several different stores before I found a board that was both long and thick enough.
Mine is 5/16" if I recall, and fits snugly under the tabs.
Graham
1984 Carrera Targa
Old 03-26-2008, 08:52 AM
cdrik915's Avatar
Specially builded for Optimas
Old 03-26-2008, 09:02 AM
Tut Tut is offline
Mitch,
That's what I thought I would do.
gtc,
5/16th is the recommended thickness, per previous posts.
Tut
'87 Carrera coupe
'08 BMW 535 xiT
Old 03-26-2008, 09:22 AM
Less brakes, more gas!
euro911sc's Avatar
I just have an AL plate in there... might be 3/16 ths at most. I have no problems with tightnes of fit.
Best regards,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 03-26-2008, 10:54 AM
Does anyone else feel a little uncomfortable with the hold down bracket right next to the battery posts?
My mounting bracket runs a similar path across the posts. I slide pvc tubing over the metal to provide an insulation barrier to prevent future fireworks.
Sherwood
Old 03-26-2008, 11:02 AM
I bought my cutting/base board from Target, it was 9.5"X 15", cost $7.99. The Optima battery that I used was P/N 999 35/75. Hopefully this is the Optima P/N and not the P/N from Carquest parts.
The above Optima battery had 4 mounting locations on the bottom of the battery so there was no need for a hold down strap. Maybe this battery is not sold any more? I pretty much copied Ed Hugh's Tech Article.
It's a great modification, no more chance of battery acid leakage...
Mitch Leland
Old 03-26-2008, 01:50 PM
