-   -   Toggle switch under dash ?? (http://forums.pelicanparts.com/porsche-911-technical-forum/171819-toggle-switch-under-dash.html)
JerDe 07-10-2004 08:39 PM
Today I discovered a toggle switch under my dashboard located under the speedometer.... any clues as to what it is ?? TIASmileWavy
carmaneddy 07-10-2004 08:42 PM
can you take a pic?
Want to be 07-10-2004 08:56 PM
This might be the extra solvent for your windshield. MY 89 25th had this too , i think it was in the same position.
jpc
Por_sha911 07-10-2004 09:09 PM
Might be a kill switch or alarm added by the PO?
JerDe 07-10-2004 09:23 PM
here's a pic:http://forums.pelicanparts.com/uploa...1089519804.jpg
usurpah 07-10-2004 09:24 PM
Passenger ejector.
Want to be 07-10-2004 09:26 PM
Looks aftermarket , i'll go with kill switch too.
jpc
JerDe 07-10-2004 09:43 PM
I like the passenger ejector theory... I'll test it out tomorrow on my wife hehe
Por_sha911 07-10-2004 09:46 PM
Mute button for the "back-seat driver" on the passenger side?
carmaneddy 07-10-2004 10:11 PM
Does it disable the ignition or cause the car to shut down?
ga_mueller 07-10-2004 11:41 PM
Unknown switch
I have one exactly like that. And I added it: it's a front oil cooler fan switch.
George
JonT 07-11-2004 05:26 AM
that looks like a trunk monkey activation switch to me
Big Ed 07-11-2004 05:30 AM
Re: Unknown switch
George
Mine too. To test if that's it, switch ignition to "on" but don't start engine. Turn toggle switch on and if its an oil cooler fan, you'll hear it start.
scooter911 07-11-2004 06:19 AM
It may also be
You may want to see if it kills the speedometer.
DavidI 07-11-2004 06:27 AM
Cool collar activation switch?
rcecale 07-11-2004 06:55 AM
Looks more like a heater control switch for a cup-holder...:rolleyes:
Randy
JP911 07-11-2004 08:36 AM
Primary power for the flux capacitor.
911pcars 07-11-2004 12:33 PM
"Today I discovered a toggle switch under my dashboard located under the speedometer.... any clues as to what it is ?? TIA"
Well, I really don't think it will ignite anything, so go ahead and switch it ON (or OFF), then tell us what happens.
Don't you have to give US some clues?
Sherwood
PS: A search in the archives might give you some clues.
JerDe 07-11-2004 05:47 PM
Problem solved !! Thanks Sherwood, I did just what you said and it IS the front oil cooler. I could hear the fan before I turned it over and it would stop when I flipped the switch. Thanks to all for the comments. Jer
911pcars 07-11-2004 06:56 PM
JerDe,
Not at all. In compensation, you can give me a ride in your 930. I can man the switch.
Sherwood
azasadny 07-11-2004 07:39 PM
Cowbell activator!
no substitute 07-11-2004 07:51 PM
Switch for a disc shaped component in the left rear engine compartment, assuming the PO didn't remove same.
jazzbass 07-11-2004 08:59 PM
LOL. I don't know if anyone else got that, but I thought it was funny as hell.
JP911 07-11-2004 09:58 PM
When you get the fever, you flip the switch! MORE COWBELL!!!!
