-   -   A/C evaporator wiring harness question (http://forums.pelicanparts.com/porsche-911-technical-forum/171855-c-evaporator-wiring-harness-question.html)
Decolliber 07-11-2004 09:49 AM
In the smuggler's box there is an a/c evaporator relay (91161510301). Into that relay is plugged a wiring harness, the end plug of which is partially melted, so I want to replace it. I have found two numbers for this harness, but do not know which is the right one:
91161298400 ($16.41 at Pelican)
90161208400 ($13 at Pelican)
Porsche parts lists show the remarks "/LL" after the first one and "/RL" after the second, but since I do not know what that means it does not help.
Can someone tell me the difference between the two and which one is right for an 88 Carrera?
And yes, I have replaced the relay with the later one that has the fuse on it.
fintstone 07-11-2004 11:13 AM
I don't know if this will help, but the PET lists the 90161208400 number as the evaporator harness for an '88. Maybe you should call PP and ask.
