-   -   When I drive over a speed bumb I hear the most awful squeeking..... (http://forums.pelicanparts.com/porsche-911-technical-forum/171888-when-i-drive-over-speed-bumb-i-hear-most-awful-squeeking.html)
svonkampen 07-11-2004 03:24 PM
Hi all,
When I drive over a speed bumb I hear the most awful squeeking from the rear suspension.....like I'm driving the truck from Sanford And Son...it sounds very embarrasing....
I can make the car squeek by pushing down on the rear of the car.......
I'm a newbie...what am I looking to replace or fix?
Car Had Koni Adjustable shocks installed about 3 months ago.....
Thanx
Cdnone1 07-11-2004 03:49 PM
Your torsion bar or bars are rubbing against something in the tube. You need to remove them, clean them and anything in the tube or mounts and if they are not damaged just put them back in. Do a search on this board and you will find great advice on indexing ride height and everything else you will need to do it yourself.
Good luck
steve
svonkampen 07-11-2004 03:50 PM
Thanx CdNone1
SvK
Chuck Moreland 07-11-2004 04:04 PM
If the noise was coming from the front suspension, the rubbing torsion bar diagnosis might be correct. But this does not happen on the rear, too much clearance for rubbing to happen.
If your spring plate or trailing arm bushings have been replaced with polyurethane, you can be sure you have found the problem. These replacements are notorious for squeaking.
If your spring plate and trailing arm bushings are original, I would suspect the sway bar bushings. You can test this by spraying the bushings with wd40. If the noise goes away, you've found your problem. Replace the bushings.
WERK I 07-11-2004 04:07 PM
svonkampen,
I had the same noise on my 930. Bad news is it was the spring plate/torsion bar bushings. I replaced both sides at once, even though it was the drivers side that was making the noise. Replaced with Neatrix bushings. What a differance it made in the ride.
svonkampen 07-11-2004 04:13 PM
Chuck,
SWB cars have no sway-bar (swaybars are post 74)
SvK
svonkampen 07-11-2004 04:16 PM
BTW thanx for helping me diagnose this issue
SvK
svandamme 07-11-2004 04:19 PM
Originally posted by svonkampen
Chuck,
SvK
eeh , nope, they came before 74 too
but i believe only S's had them , maybe E's too , not sure
i lost mine actually , it's somewhere in the friggin garage, wanted to bolt it back on after i dissassembled my ride 7 months ago, and somebody probably though it was a stupid metal rod in a funny shape :mad:
Cdnone1 07-11-2004 04:20 PM
I stand corrected. i had noise coming from the front and that was what it was. Thanks for the advice. I would have hated to send SvK down the wrong road, esp. since he just lives down the coast from me.
Bill Douglas 07-11-2004 04:56 PM
Spray a bit of silicon around the place and see if the noise goes away. Mine turned out to be the front sway bar bushes.
svonkampen 07-11-2004 04:57 PM
Will do Bill
SvK
