-   -   Turn signal stopped blinking (http://forums.pelicanparts.com/porsche-911-technical-forum/172012-turn-signal-stopped-blinking.html)
nkader 07-12-2004 09:56 AM
Yesterday I noticed that my turn signal stopped blinking on the dashboard. I parked the car and checked to see if it was blinking outside the car and it was not, just a solid yellow light on either side.
What do I need to do to get it blinking again?
The car is a 1969 911 T.
Thanks for your help,
-Nino
steve911 07-12-2004 10:05 AM
Nino--
I'm going to guess that a relay has gone bad, but the electrical gurus here will surely be able to tell you more definitively.
nkader 07-12-2004 01:25 PM
Does anyone know where the turn signal relay is located?
JTO 07-12-2004 01:27 PM
I had a problem like this and found that the bulb was faulty; it made intermittent contact in the housing.
Troy
sithot 07-12-2004 01:32 PM
Relay
Pull out your oil level/temp gauge. Use a flashlight. It's behind the gauge mounted just forward and down. It's black. If it cooked itself it will show signs of getting hot. They do wear out.
I don't have the part number but don't get an aftermarket one from Autozone or anywhere else. Use a Hella piece and it will work flawlessly. I've had experience with the ones from BAP/GEON and NAPA.
Good luck,
Tom
ruf-porsche 07-12-2004 02:18 PM
Bad flasher or bad bulb.
nkader 07-12-2004 03:33 PM
It is a bad flasher. The bulbs all work just fine.
fintstone 07-12-2004 09:02 PM
Lots of good troubleshooting links in the recent past for turn signal problems if you do a search. here are just a couple:
http://forums.pelicanparts.com/porsche-911-technical-forum/163008-turn-signal-relay-71-a.html
http://forums.pelicanparts.com/porsche-911-technical-forum/153612-flashers-not-emergency-yes-whats-up.html
Emission 07-13-2004 12:15 AM
My first DIY replacement on my Porsche was the turn signal assembly...
