-   -   Teething Problems with 77 911s (http://forums.pelicanparts.com/porsche-911-technical-forum/172426-teething-problems-77-911s.html)
unclebilly 07-14-2004 12:29 PM
I've just started to drive the car I hauled from Ohio to Alberta last week and am having some problems...
Problem #1
The idle hunts and often quits - I've scoured the board and this seems to be the mixture setting which I plan to adjust (for now I just increased the idle). While I was doing the idle, I noticed a vacuum port with no line connected (1st vacuum leak), it is on the throttle body right near the air box - any ideas what should be connected there?
Problem #2
The car sometimes won't start hot - fuel accumulator is my guess. It just cranks and when it does fire it stumbles at first.
Problem #3
The car sometimes won't even crank - all I get it the fuel pump relay clicking when I hit the key. Eventually it goes - starter solenoid is my gues from 15 years of working on Detroit Iron.
Any help or suggestions would be appreciated.
MichiganMat 07-14-2004 12:36 PM
Problem 2: replace the fuel check valve first, its cheaper and it fixed my hot-start problems.
Problem 3: check/replace battery terminals, cables, and all connections. My SC wouldn't crank over either until I changed it all.
Paulporsche 07-14-2004 07:03 PM
If you do some searching you will find some photos and some diagrams and exploded views showing how the vacuum lines are routed.
Your idle hunting is probably caused by a too rich mixture, although you should fix that air leak before you change the CO setting.
This should help w/ Problem 1.
