Maybe I should have posted this here: http://forums.pelicanparts.com/porsche-911-technical-forum/783409-need-help-malfunctioning-cab-top.html
BTW I am more and more leaning to the conclusion that the most likely cause of my problems is one or more broken wires in the last 10 cm of the harness connecting to the roof control unit. Does anyone know if this is a separate harness? Is there a connector somewhere further down? I think based on the drawings I have seen there should be, that could make rebuilding the harness much easier. My other option is to just cut off the last few cm and re-solder the 4 connectors. Thoughts? I also found that some of the gears in the right hand side latch motor are stripped. Any idea where to get the gears from, without paying 500 - 1000 USD for a complete new motor? Has anyone got a damaged motor with good gears? |
Taken more out of Pelican than I've put back so, to address that... here's mine.
http://i164.photobucket.com/albums/u...psc0679136.jpg http://i164.photobucket.com/albums/u...psdca95230.jpg http://i164.photobucket.com/albums/u...ps0a9349d3.jpg Ride height is down to 50kg (110lbs) weight loss. Plan is backdate the rear and narrow IROC front like Green Meanie. |
1988 M491 M470 Cab w/ track wheels
My favorite
Best looking cab?
still wrenching.....
random question of the day (you've been warned)
does anyone know where i can find the lens for the convertible top light on the dash? this is the light that sits between the tach and oil pressure gauge. i have the light and it works, just the red lens is missing. (i told you it was random) |
What you see on the car is quite a bit of dust as I have been remodeling my master bath and cutting wood in front of the garage. The paint though is a bit oxidized and will be the final stage of my rehab after the engine is back in, seats recovered, and top replaced. |
I think you need to talk to Madame Blancheville (Kathy) but don't say its from me :D:):D |
Fortunately this projct is 97% complete so I'll be able to dedicate more time to get the car back on the road. BTW it was at Madame Blancheville's suggestion the we got the Porsche... She's a keeper!:D |
can anyone help me locate this part? it's the cabriolet top "indicator" light. i only really need the lense itself but would consider the entire unit if need be.
http://i619.photobucket.com/albums/t...ps66fc1800.png |
I can't help with sourcing the lense but my '87 came without a lens so I made my own from a red bike reflector using a dremel. I press fit it in and is still in there after a couple of years. Not OEM but it looks the part. I took the bulb for the light out when I unhooked the transmissions turning the top to manual causing the light to be on constantly. Having the lens in there did finish off the look.
Ken |
Thanks for the info kkkarpuk. Just curious, what does this mean anyways? When it's fully closed or opened?
One other question for all... Has anyone changed out their speakers and head unit? I want to get better sound in my cab but I don't want to go tearing up the interior. I intend to keep this as stock as possible. Thoughts anyone? |
| All times are GMT -8. The time now is 03:27 PM. |
