How does factory determine redline?
I've always just thought of it as a line on the tach that I ought not pass. But who decides where that line is? And more importantly how do they make that determination?
I would assume that the early cars that had the rare (if ever equipped) factory option of titanium rods would handle a higher redline than stock. But if you paid the extra $1K for Ti rods, did you get a different tach than the rest of the Ts, Es, and Ses? I doubt it. So how does an engine builder determine what an engine's redline is?? Or is it simply an estimate??? |
It's where they stopped throwing pieces 99% of the time.
Just a Wag. |
its a math question and Ill get it started..the piston is always accelerating away from the fastest pt 1/2 way between tdc and bdc and as I understand it the engeers use this as the loading facter more than anything else for the generated forces mass and stuff.
Corky Bell" max boost" has a good simple ans in his book and is very good reading |
often the valve train is the issue.
The Engineers set the redline at the factory by determining that if it was an Italian engine where would it blow up. They then added 15% and called it good. |
The idea that Ti rods were optional on street cars is, IMHO, a myth that the <b><i>Car and Driver</b></i> crew decided to start just for laughs ... much like their promoting the '64 GTO 'ringer' that the Pontiac engineers prepped for bouts on Woodward Ave. ... as a world-beater 'production' car even though the test numbers were never duplicated by any other magazine, and certainly not by any stock cars in reviews or revisits many decades later!!! The fact that Patrick Bedard decided to promote the myth for 2.4 engines is laughable, considering that Ti rods weren't used in 2.8 or 3.0 RSR engines!
Redlines are generally dictated by the camshaft pofile and hp/torque curves exhibited by a particular engine ... not by destruction tests! Uncounterweighted 911T engines don't blow up at 7000 rpm, so quit worrying that some demon from the Black Forest is going to rear its' head and bite you if you rev past the redline on the tach on a pre-84 engine! The 3.2, 3.3, and 3.6 engine with stock 9 mm rod bolts are a special case, and their redlines should be observed carefully! |
I'm not certain about that. I have been told that the stock numbers for all reciprocating parts on a 84-89 Carrera are identical to those on the same years turbo. The turbo has a 7200 rpm redline versue the Carrera's 6200????
Warren, would you mind please clarifying the "doom" part of your above post? What happens if you violate redline in a 3.2?
TIA, Dan |
Per Frere, the redline on Turbos was 6950 rpm, and 3.2 normal engines had a chip-set redline of 6520 rpm, Club Sports were 200 rpm higher!
Many stock 3.2 engines have self-destructed in a rather dramatic way at DEs after extensive sustained speeds above 6700 rpm. The problem has been documented many times in BA's technical column in <b><i>Excellence</B></i> and at PCA tech sessions! The 'standard' recommended precaution to take with 3.2, 3.3, or 3.6 engines to be tracked seriously at high-rpm is to install ARP or Raceware rod bolts ... |
With afew mods, you are supposed to be able to spin these engines at 8,000
Ti keepers, better springs & the famous rod bolt fix. |
I suppose the factory could have used "failure analysis" ala HAL9000 and that would have revealed both at what RPM the failure occurred and what part failed. But I would think that it would be more involved than that. You could blow up a lot of engines before you uncovered a consistent pattern.
This is purely a theoretical question for me. Not something I need to know, but a question I've always had, the answer to which might teach me a bit more about engines - how they work and why they fail. Aside from that, I'm bummed to think that the Ti rod option is a myth. Of course it doesn't make sense, but it was cool enough sounding for me to buy into. I wonder what other Porsche myths I believe??? |
How complex would it really be to build an engineering simulator to figure out what the failure point of an engine would be? I mean, ultimately, it comes down to the polar moment of a variety of small bits and pieces, spring rates and momentums for valves, error tolerances on a variety of rotational components ... wait, this sounds _way_ more complicated than I'm likely to figure out over my morning latte. Nevermind,
Dan |
djm - simpler engine simulator programs do exist to predict engine capability (GT-Power), but none point out the direct failure point. That would be a much more complicated simulator that requires dynamic motion simulation combined with nonlinear structural/thermal analysis and maybe even CFD. Big, big computer running for a long time - OEMS don't spend that much time in one area. Simulations get you to a point, but eventually it's time to build and break it - and that's the fun part :)
Redline is typically where UNCONTROLED valvetrain motion takes over where the changes of catastrophic engine failure are much higher. High RPM CONTROLLED valvetrain motion is an art/science in itself with many, many variables. Lighter valvetrain components and cam profiles are just where you start to bump up redline. |
even S-cams loose effectiveness beyond 7000 RPM the only advantage for readlining an S, is to get in the better RPM range when upshifting http://forums.pelicanparts.com/uploa...1089913050.jpg at least that's how i understand it... |
Holy smokes!.....
Even if you could figure out the theoretical failure point...you then need to consider the variability of the individual parts...from a statistical variability point of view. Simple example: Take *identical* paper clips...made with the same material , same wire diameter, same quality control...same *everything* that is humanly possible to control...and do an experiment. Bend each one back and forth exactly 180 degrees and count how many flexes you have until failure. Big surprise ( to some of you anyway :) )--- there will be a statistical variation in the results...most likely in the shape of the classical "bell-shaped" curve. Meaning? A very few will fail very early...and a very few will fail very late...but most will fail in the middle/peak of the curve. Upshot? Absolute prediction is impossible....can only be described as a a statistical probablility. ---Wil |
So the answer I think I'm getting here is that the manufacture's redline point is probably based on something like 10% below the leading edge of the bell curve of failure points based on a simulation -with the likely failure points being the valve train and the rod fasteners. It does seem like the valve train would fail first.
For some reason I thought the answer would be more complicated. |
That's just it..it IS complicated..
Lessee...how many failures...from a probability standpoint, will the manufacturer tolerate knowing that "X" percent will be claimed under warranty? Zero?...probably not...much too conservative. 5% (?)...even that may eat his lunch, and may be too much. And all this assumes your "predictive model" is correct on all counts..that you can mathematically model the entire design/ construct process.... We haven't even begun to talk about the trade-off of performance and reliability.... It can't be very simple...IMHO... ---Wil |
This is kinda off the subject....but how do those Formula 1 engines turn over 18,000 rpm's! Unbelievable!
well F1 engines as I understand are large bore and extremely short stroke motors...so they move alot of air with a small stroke length.
plus it is usually valvetrain issues that blow engines...F1's solution...pneumatic valve train so there are not chains and springs which can lead to "float" situations I really doubt Porsche is redlining engines till they blow up...doing this 100 times and coming up with a redline...I am pretty sure they's have a materials specialist do some calculations and figure out the failure point of some of the components...then use a good % of saftey margin for the consumer. (plus I am sure they had real data of cars that did blow up during test runs and racing to help determine more accurate redlines) Now a days it is most likely a comupter simulation model that calculates a theoretical failure point...then throw in some testing data...engines that were run hard and torn down inspected for wear and damage...voila your consumer redline MJ |
In my car Redline is just a suggestion ;)
| All times are GMT -8. The time now is 01:17 AM. |
