Time will not pass fast enough!!!!
Talked to the shop, and he will be finished with my car today!!!!!
I'm now officially hyper and can't get any work done. Maybe I should just start driving to the shop now... Things I know he's fixed... pedal cluster rebuild new master cylinder new brake lines new rotor new cap new points new plugs new oil filter new tires new fuel lines around the engine lots of wiring fixes, the lights work, and the engine starts reliably adjusted the throttle linkages fixed the tach (part of those wiring fixes) replaced that piece of Mack Truck airbrake hose that was serving as a throttle linkage coupler He decided to not adjust the MFI as the car was not hesitating between 2800 and 3200 RPM unlike most MFI setups he gets, so he's leaving mine alone for now. I can't wait, pictures will follow! Britt |
| All times are GMT -8. The time now is 02:12 AM. |
