Cleaning hubs and assorted wheel and suspension parts...
I know there has been bad exprience with cleaning alum and mag cases with simple green, but what about soaking hubs and similar stuff in it? I need to remove some serious grime before bead blasting (if it is necessary following grime removal). Any other solvent suggestions for this? I have access to buckets of good stuff at work...
Thanks!
-Brian
Old 05-04-2006, 08:01 PM
randywebb's Avatar
for grime ( = greasey, non-polar crud) use a solvent tank
for polar type stuff ('dirt') use a strong detergent
I wouldn't soak anything in S Green or Castrol Purple (which removes paint BTW) spray it on scrub and rinse off w/o waiting very long. See how things look.
Think about soda blasting or plastic beads for a real new look.
Hot water and elbow grease are like magic.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 05-04-2006, 09:34 PM
Product "Oil-flow" works well and is not aggressive....takes cosmoline off rather well, etc...
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 05-05-2006, 06:12 AM
