Somatic Negative Optimist
Gunter's Avatar
Question '76 turbo valve clearance, cam timing and ignition ?
Specs needed: Ignition ????deg BTDC? Valve clearance? Cam timing? Thanks
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 08-11-2004, 02:37 PM
Gunter's Avatar
bump
Old 08-12-2004, 09:19 PM
rlh930's Avatar
Check out http://www.vipgroupinternational.com/catalog.htm - in a week you can have all this information at your fingertips.
Roger
'87 930
'73 911T
Old 08-12-2004, 10:27 PM
29 degreee @ 4000 rpm with vacuum advance disconnected.
CAM timing: 0.65-0.8mm @ .1mm valve clearance.
HTHs...
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 08-13-2004, 07:00 AM
Gunter's Avatar
Thanks Patrick: What type plugs?
Old 08-13-2004, 10:05 AM
I use the factory recommended W3DPO. Not sure if its the same for earlier turbo or not.
Old 08-13-2004, 12:07 PM
Gunter's Avatar
Thanks again, Patrick. Are they Bosch copper?
Old 08-14-2004, 07:30 AM
