Taking off front fenders
How hard is it to do on a 77 911 and how about the wires going to the Headlights in the front. How are those handled? I know how to take the lights off the car, I am just not sure how I could take the fender off if the connection for the headlights is still tying the fender to the car.
Thanks,
Old 07-20-2004, 05:42 AM
dickster's Avatar
havent done it (on a 911) but usually taking it off is the easy bit - getting the bugger lined up when you put it back on is the hard part!
rusted fasteners aside of course.
Rich
'86 coupe
"there you are"
Old 07-20-2004, 06:12 AM
not "hard" to do. Tedious to do.
wires get disconnected and snaked out.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
djmcmath's Avatar
I did this to my '86 this spring -- long slow painful process to remove them without bending them. The wiring turned out to be a non-issue, really. Disconnect and pull back through the holes. Rusted fasteners will slow you down, and the undercoating required the application of a heat gun. So did the gluey stuff between the fender and the body. Plan on spending a few solid hours on each side looking for that one missing fastener, or gently prying with a putty knife and the heat gun.
Good luck,
Dan
'86 911 (RIP March '05)
'17 Subaru CrossTrek
'99 911 (Adopt an unloved 996 from your local shelter today!)
Old 07-20-2004, 06:33 AM
