sayah's Avatar
Speedometer Cable Length Question
Does anyone know the correct lengh for 911 speedometer cables. I am considering having a new one made and the people at the shop doing the job seem to know what kind of ends to put on it but want to know the lenght.
Thanks for informed responses.
sayah
Old 07-18-2004, 05:25 AM
Early_S_Man's Avatar
Porsche Crest
What year car?
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-18-2004, 08:49 AM
sayah's Avatar
The car is a 1975 911.
sayah
Old 07-18-2004, 09:39 AM
You can use 901 741 111 01 (this part is available), which is the substitute for 901 741 112 01 the current part number for that car. According to the info I have the cable is 2442mm long.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 07-18-2004, 10:50 AM
Halm's Avatar
Learned something the hard way last Fall about the cables. Seems that the one available for early cars is slightly longer than the original one. The slack from the extra length must be spread out equally between the attachment points. In other words, don't just stick on there and let the extra length find a home. If it is not equal, it will snap within 100 miles.
'17 Cayenne
Old 07-18-2004, 11:55 AM
sayah's Avatar
My math is terrible, does that make it 244 cm long?
sayah
Old 07-18-2004, 12:45 PM
Pat S's Avatar
What do you mean by spread out equally? I'd think as long as it isn't kinked or bent sharply anywhere it should be fine?
Pat
Old 07-18-2004, 02:30 PM
Halm's Avatar
Pat
Pat, what I am trying to describe is that the exta length has to "live" somewhere, either in the area of the speedo, or at the transmission. Let's say that the new cable is 6 inches longer than the original. Then 3" of the new slack should be at the trany, and 3" at the speedo. Don't put it all, for example, up in the dash at the speedo.
HTH
'17 Cayenne
Old 07-18-2004, 02:50 PM
Pat S's Avatar
Okay. I guess the 901 has a different connection than the 915s. On the 915 there is no place to store the extra on the tranny side since it goes straight into the tunnel. If you pulled it back some there you would have one heck of a kink
Thanks,
Pat
Current: 07 S4 Avant, 06 Volvo S60R
Sold: '74 911, 01 986, 93 Volvo 240
Old 07-18-2004, 02:58 PM
Send a message via AIM to fintstone
I have a new one in my garage labeled 90174111101 (64-76 911) that I purchased a while back. It is about a foot longer than that at about 109 inches or about 2768 MM. The label is handwritten, so the part number/fitment may be incorrect.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 07-18-2004, 07:00 PM
Halm's Avatar
FWIW, I was told that I had to use the longer one becaue the original length was NLA.
'17 Cayenne
Old 07-18-2004, 07:09 PM
sayah's Avatar
The longer one with excess lenght is noisey right up behind the speedo.
sayah
Old 07-19-2004, 04:11 AM
