North Coast Cab's Avatar
Rear Sway Drop Link Bushings
Can I just replace the rubber on the rear sway bar drop links? I can't seem to find anything on Pelican. It's an '84 for with a later 21mm sway bar.
Thanks, John
1985.5 944 GTS
Old 07-20-2004, 05:05 PM
gduke's Avatar
No, you need to replace the whole drop link. They're only $35 ea, and take only 10 min. to replace.
1985 911 Carerra Cab 3.6l
1998 Dodge Ram
2004 Toyota Tundra Quad Cab
Old 07-20-2004, 05:13 PM
Mine look like this
The ones on Pelican look like this.
John
1985.5 944 GTS
Old 07-20-2004, 05:34 PM
Binge User
Schrup's Avatar
Or you can upgrade to these as I did. They are Tarret adjustable rear drop links. The host sells them.
Paul
Old 07-20-2004, 05:39 PM
Paul,
Those are sweet. What does the off center bolt thing do?
John
1985.5 944 GTS
Old 07-20-2004, 06:05 PM
gduke's Avatar
John, the ones I bought from Pel. are the same as in your pic. Call, the sales dept. They can help you.
1998 Dodge Ram
Old 07-20-2004, 06:30 PM
4 Heilm Joints for $130, seems a little outrageous. I'll see if I can locate.
John
1985.5 944 GTS
Old 07-20-2004, 06:34 PM
CBRacerX's Avatar
Not so outrageous...
I've paid that much for ONE heim joint used on a formula car upright.
Nice item though....
Chris
Old 07-20-2004, 06:59 PM
Randy Webb's Avatar
Heim joints (observe spelling) are common. Do a Google of Froggle.
Old 07-20-2004, 07:08 PM
CBRacerX's Avatar
Common yes,
Equivalent no. In this case, if it breaks, no major catastrophe. On the other hand, if this is on an a-arm, you need to be a bit more discriminating...
Chris
Old 07-20-2004, 07:20 PM
Jeff Alton's Avatar
Those drop links are only 100.00 from the manufacturer. www.tarett.com
Jeff
www.turn3autosport.com
Old 07-20-2004, 08:03 PM
Binge User
Schrup's Avatar
Originally posted by North Coast Cab
Paul,
John
John, no idea, they didn't come with the drop links, nor were there any directions. Maybe they're a spacer for the bolts that attach them to the bannana arms, although they don't look large enough. When I had my car aligned, the guy advised me to get some spacers so the mono balls were centered in their range of movement.
Paul
Old 07-20-2004, 08:13 PM
Randy Webb's Avatar
CBracer - You think they are made of a special alloy?
Old 07-20-2004, 08:42 PM
Chuck Moreland's Avatar
Those adjustable drop links are designed to connect to the spring plates instead of the trailing arms (as the factory links do). They connect to the toe adjustment on the spring plates, hence the eccentric which replaces the factory toe adjuster. So yes, there are some custom made parts there in addition to the 4 rod ends.
Chuck Moreland - elephantracing.com - vonnen.com
Old 07-20-2004, 09:21 PM
Binge User
Schrup's Avatar
Chuck, any idea why these statements appear on Tarret's web page? Are they marketing the item to be used in a different manner than they were designed?
"Upgrade your stock swaybar with this simple bolt-in replacement for the factory drop links. Adjustable length to eliminate swaybar preload. Oversized, precision Teflon-lined rod-ends for long life, smooth operation, and high-reliability. Eliminates the factory compliant rubber drop link bushings for improved swaybar response. Precisely connects the stock swaybar to the rear trailing arm."
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_suspen_pg5.htm#item12
http://www.tarett.com/911_rear_drop_link.htm
Paul
Old 07-20-2004, 11:33 PM
New Panorama yesterday. Page 28 www.hirschmannusa.com
John
1985.5 944 GTS
Old 07-21-2004, 03:22 AM
CBRacerX's Avatar
Randy,
I don't think these are particularly special heim joints, they look pretty average from the photo. My comments are simply noting that the cost does not seem outlandish for the product, and 'sourcing your own' may not really save you any money (given there are a couple of custom machined parts there also).
Cheers,
Chris
Old 07-21-2004, 05:08 AM
Drop links provided with Tarett sway bars can be attached to either the trailing arm or the spring plate. The spring plate is recommended and offers greater range of motion.
I assume their adjustable drop links offer similar attachment choices.
In any event, that is what those eccentrics pictured are for - spring plate attachment.
Old 07-21-2004, 08:53 AM
