rolling fenders...paint crack?
With my 7 & 8's on the 87 I have a rub on the drivers fender lip going over bumps.
Who has rolled their lip and had no paint cracking? only on the lip, or visible from outside. What can the camber/ toe be set to ...to help? PLEASE dont say ...use the search button...it takes too long.
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted. |
I've rolled both fronts to some degree. Probably not as much as I should. Got just a little cracking - not visible from the side of the car - you have to look up at the rolled lip to see it. I had to raise my car a little because of the rubbing. I've now got just about -1.4 degrees in the front and still get a slight rub under certain conditions. I'm sorry I didn't put 23 mm torsion bars on the front instead of the 22s. I think that might have helped.
"Life is good" |
Warming the paint with a heat gun will soften it and reduce the chance of cracking.
Chuck Moreland - elephantracing.com - vonnen.com |
I have 8 1/2 17s on the front and rolled the lips with no crackingbut I still rub on turns with bumps. Don't know settings but will find out.
Gerry 84 911 Carrera (Supercharged), 67 427 Vette , 67 XK E-type Rdstr., 56 Vette 06 Cayenne Turbo S, 08 Vette Coupe, 57 Vette, 65 Chev Nova 327 4spd 65 Chev Nova 385 Race, 85 Chevy Rollback 97 Ford Exp. EB, 90, 91 Toy PU |
Re: rolling fenders...paint crack?
Rolling fenders - how to avoid paint cracking fender rolling techniques Fender rolling tool Fender & Tyre Damage Rolling fender lip Rolling fenders - the old-fashioned way Leland...lip rolling fender rolling Show me rolled Fenders! 225s on the front I could go on and on (there were many more results), but now it is your turn to do a little work.
Andy |
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Thanks for the links guys.......
time constraint......I am working
Ken:
I put 7s up front on my 84 and had the same problem. I had the camber adjusted, did not roll my fenders, and the problem was solved. I'd rather have a little extra tire wear than risk cracking the paint! I'm sorry, but I don't know the settings. TRE here in LA did the work. Scott
1984 Targa |
thanks scott. Part of my dilema is the 87 is all original paint with virtually no chips or marks. I really hate to chip an all original car with 47k on the clock. maybe I will dial in neg cam first.
Ken:
I'm in the same boat as you...all original paint, and didn't want to take chances. Talk to your wrench. He'll know how much to adjust the camber. Alternatively, send an e-mail to TRE Cup and ask Dave for the specs. He's a good guy, and I'm sure he'd be happy to help. Scott
1984 Targa |
