dual muffler cut-outs
How did you cut the rear valance for the dual muffler setup?
Anyone have a secret method so I will not have to repaint the entire panel??
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted.
Old 07-22-2004, 12:38 PM
North Coast Cab's Avatar
I measured about ten times and then cut with tin snips. The paint remained in good shape. I touched up the edge to prevent rust. Typically the valence gets a lot or rock hits and chips anyway. For about $20 you can buy a spray can of lacquer touch-up and respray the whole thing.
John
1985.5 944 GTS
Old 07-22-2004, 12:44 PM
I have an all original paint ....no chips car and really want to hear the 3.2 sing.
I will probably get a ghl single in/out set-up to suffice.
Old 07-22-2004, 12:55 PM
GB83SC's Avatar
Take a piece of cardboard and make a template of the drivers side opening, flip it and use it to mark the area where you need to cut the right side. I used a dremel to cut, this worked fine for me.
Good luck.
George
My Owners Gallery Page
1983 911SC - Built July 1983 #2547 out of a total 2559 shiped to the US. in 1983. Could be the last U.S. production SC still running.
1995 BMW 525I
2001 Highlander- kid mover
Old 07-22-2004, 12:57 PM
MBruns for President
JeremyD's Avatar
Good luck.
I'll second that - mine had a major curb rash - so I just cut out the area with the curb rash... So it wasn't an exact match, but I am fine with it...
Old 07-22-2004, 01:10 PM
I did this and posted a number of times on this topic. Do a search.
Sure..a template for the right side is nice, but I would go a bit further for that "factory" look.
Two things...
1.) I would cut the right side hole ever-so-slightly smaller, and use a padded vice-grip to create a small "edge lip" ...like a fender lip to give it a bit more visual depth and strengh. Touch up with paint.
2.) Cut the hole in such a way so that ( from a car's side view) the right-hand hole has a 45 degree "front" edge on the valence...don't just cut a hole and leave-off the front edge of the "hole". Why? Thr right side rocker panel behind the rear wheel ends at a right angle ( where the normal valence "slides under" in an accident), whereas the left original rocker is sloped in a 45 degree angle. Unless you you go the RUF route by completelely replacing the right side rocker with a new one with the appropriate slope...this is the next best thing to give it the "detail" a Porsche deserves. This way , both sides match ( sort-of) with similar 45 degree front-edges of the hole.
---Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 07-22-2004, 01:23 PM
adamred's Avatar
NYC
A NYC curb took care of it for me....
But then I used tin snips to clean it up as suggested earlier. It is very soft metal...
Adam
Adam,
2019 BMW 540i
Old 07-22-2004, 02:04 PM
There's a good video on the Fabspeed website where they explain how they do it.
http://www.fabspeed.com/911T-930%20Dual%20Out%20Valance%20Cut%20info.wmv
Hope that helps,
-Ian
Old 07-22-2004, 02:57 PM
Me like track days
Craig 930 RS's Avatar
Jeremy, I'm diggin' your photoshop license plate!
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 07-22-2004, 03:13 PM
Exclamation Dual cutout
Ken,
I too would suggest a dremmel. As that is how I did mine.
Any way which you choose to cut it make sure that tape off te area with masking (painters) tape first to minimize (eliminate) any damage to the paint. Cutting bare bumper/valance will most certainly chip.
Good Luck.
Jeremy C.
Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham)
----Nothing is far away in this car!---
-2001 996 Turbo
Old 07-22-2004, 03:31 PM
JeremyD's Avatar
Thanks craig - don't want someone showing up at my house with an order for a Diamond Blue 911 Cab - gues I have watched gone in 60 seconds too many times...
Old 07-22-2004, 03:39 PM
